Aironet 1602e on 2504 Controller
INSYSGROUP
I was wondering if there was a way to include additional AP configuration information on the controller.  I'm trying to program the following on some Aironet 1602s:
1.  Program the timezone to Eastern
2.  Program daylight savings to EDT (recurring)
3.  Program the correct antenna DBi information
I know this is a bit trivial, but I'm a little picky.  I can program this info, but every time an access point is restarted, the info is lost.
Mike R.
Leo Laohoo
Once you configure the Country and the timezone, DST would be automatic.
Go to Wireless > Access Points > Radio > right-hand of the AP and choose "Configure" > go to "Antenna Parameters" and enter the value under "Antenna Gains".
If your antenna is, for example, 4 dBi then the value entered is "8".
I forgot to mention, the controller is running 7.4.0.60 firmware.  I tried looking into the wireless settings, but I didn't see it.
The antenna DBi is entered for both radios (2.4/5 GHz).  I know you can set it in the CLI, but I couldn't find it on the 2504 controller.  Any chance you can throw a couple of screen shots?
Thanks.
