WPA/PSK Auth. Problems with spec. Linux Client
cancomservice
Community Member
I have a client who can not authenticate on an autonomous Cisco wireless AP with his special WLAN client?
Result: Authentication mismatch
If I use a TP-Link or Netgear AP, the specific wireless client can authenticate! No problem.
All other wireless Klients (eg Win7, iPhone, Android, etc.) have no problems with the Cisco AP. The authentication WPA2/PSK working properly.
I have tested it with an AP1142 and 2620i (IOS 12.x and 15.x). The spec. Client can not authenticate?
Do you have experience with such a problem and can you give me tips why.
What debugging commands should I use to see more?
Information of WLAN Client:
OS: embedded Linux based on the kernel 2.6.34
WLAN Stack: mac80211 Stack, after my info has no own version and refers to the kernel version (2.6.34)
Motherboard: They have no commercially available PC but its own system. Motherboard is therefore our CPU module with a Marvell PXA166 processor as the main.
WLAN Stick: Netgear WNA1100 they operate with the driver ath9k_htc
They also use our system to the wpa_supplicant v1.0
Access-Point Conficuration:
version 12.4
no service pad
service password-encryption
hostname DOP-AP-1
enable secret 5 xxxxxxxx
no aaa new-model
dot11 syslog
dot11 vlan-name Pruefnetz-WLAN vlan 135
dot11 ssid DOP-WLAN-Pruefnetz
   vlan 135
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxxxx
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 135 mode ciphers aes-ccm
antenna gain 0
mbssid
speed  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 128 drop-packet
channel least-congested 2412 2437 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.135
encapsulation dot1Q 135
no ip route-cache
bridge-group 135
bridge-group 135 subscriber-loop-control
bridge-group 135 block-unknown-source
no bridge-group 135 source-learning
no bridge-group 135 unicast-flooding
bridge-group 135 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
antenna gain 0
no dfs band block
mbssid
channel width 40-below
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.135
no ip route-cache
bridge-group 135
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.135
no ip route-cache
bridge-group 135
interface BVI1
ip address 10.4.0.72 255.255.0.0
no ip route-cache
ip default-gateway 10.4.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
password 7 070D2E44400C2616001B
login
end
Thanks for help
Alexander
0 Replies 0
