aironet 1700 AP radio 5ghz interface is showing down.
ABPDIGITAL
Hi All,
Mine cisco aironet 1700 series AP 5GHZ radio interface automatically get down even though under settings option it is enabled. Please find the attached SS.
JPavonM
Check whether the country code you have configured for the AP matches the hard-coded one stated by the AP model.
Can you help me here to identify what should be the country code here.
The country code should be the country you are in!
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/country_codes.html
And the AP needs to be licensed for use in that country so the regulatory domain of the AP needs to be approved for your country.  You can check the AP model at https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Using an AP in a different regulatory domain to what it is approved for is illegal in most countries.
What country are you in?
What is the full model number of the AP?
