Aironet 2600 Series AP (AIR-CAP2602E) to Autonomous
loolianwee
I purchased the AP wrongly, instead of getting the "Standalone/Autonomous" (AIR-SAP2602E) version but I purchased the controller-based version
(AIR-CAP2602E); my question is can I use "ap3g2-k9w7-tar.152-2.JB.tar" too flash it to a "Standalone/Autonomous" version?
If yes, can anyone help to point me to the right "Flashing method" and things required like console cable or just "ethernet cable" will do? Appreciate it!
24 Replies 24
Yes, all off.
Found the issue! Just rename the file extension and not the file name, the AP keep looking for ap3g2-k9w7-tar.default instead of c2600-k9w7-tar.default.... It is transfering the file now, i will update the status when completed. Finger crossed.....
That will do it... you can see the filename its looking for on the console when you relase the mode button.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
It does not go through, it gets timeout half way during trasnfer....
Verify the MD5 and make sure it matches.  Might have a corupt download image file.
Scott
-Scott
There isnt a md5 for me to verify, i do not know the original md5.
When you download the image, if you hover your mouse over the filename, a pop up will appear with the MD5.
-Scott
Yes, MD5 is correct..... when trafering the transfer rate keep going down....
Can you attaqch the output from the console so we can see what is going on.
Scott
-Scott
Here is another way of doing it
https://supportforums.cisco.com/docs/DOC-18268
Scott
-Scott
Hi Scott,
I have the following with me.
1. AIR-MSE-3355-K9 - 1 Nos
2. AIR-CT5760-50-K9 1 Nos
3. AIR-CAP2602E-N-K9 - 5 Nos
I want to
1. Use one of the 5 AIR-CAP2602E-N-K9 as an IPS
Is this possible, I want to know how. Can someone please guide me to the right documentation for it?
