Aironet 2702 Autonomous mode
piovesam1
Hi !
Please, can anybody confirm (or not) if the Cisco AP 2702 works in autonomous mode?
The documentation says that it works in standalone mode:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2700-series-access-point/datasheet-c78-730593.pdf
".. Controller-based deployment and standalone deployments."
But I can't find any setup for it, and even a real deployment without a WLC (maybe because it's a new product?).
Thanks in advance!
Regards.
Eduardo Piovesam
8 Replies 8
Sandeep Choudhary
Hi Eduardo,
Yes this AP also work as Autonomous.
But Still cisco did not released the rght firmware for this.
**** As cisco says:  2700 is new, the autonomous IOS is for wireless site-survey only.  It's not meant to service clients as of yet.
Dont forget to rate helpful posts
Hi Sandeep,
Do you know if the newest release (03-september) contains the "full autonomous mode"?
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ios/release/notes/rn-15-3-3.html
Thank you.
Eduardo Piovesam
This is brnad new IOS:
I did not test this but I think this is full autonomus mode.
2700i:
http://software.cisco.com/download/release.html?mdfid=286256843&flowid=50363&softwareid=284180979&release=15.3.3-JAB&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Hi Sandeep,
Could you please confirm if this image really supports the full autonomous mode in 2702e (maybe talking with someone at Cisco)?
Thank you!
Eduardo Piovesam
ewood2624
Level 5
Level 5
Does the autonomous 2702 code support 802.11ac or is it controller-based only?
Yes, this version is fully 802.11ac supported
ap3g2-k9w7-tar.153-3.JAB.tar
Rasika
**** Pls rate all useful responses ****
Just tried to convert a controller connected 2702e to autonomous mode with no success. I loaded the above mentioned image via the archive command but this ended up with the following error message on the controller:
AP with MAC: 7c:0e:ce:b9:49:80(AP1c6a.7abb.1d04) upgrade image from verion:8.0.100.0 to 8.0.72.236 failed. Failure Cause:Problem extracting image tar file or image is not a valid.
Any help would be really appreciated ...
rene
Try to use the mode button option described here & see if it end up similar fashion. Log the AP console output  while doing this & attach it to see if that fails again.
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
