Aironet 350~~ Help Factory Settings must be RESTORED
Sanfordadmin
I am the proud and happy new owner of the Cico Aironet 350 wireless access point. Now the issue (acquired by the company's buyout of another one), needless to say when I get it there is no username/passwords included. Just the cable/power supply and the wireless access point it self. Has anyone here ever worked with this unit before and if you have, do you know how to reset to the factory defaults?
Rob Huffman
Hi Joshua,
Here is the method to do a factory reset;
Reset the AP 350 That Runs Cisco IOS Software
Complete the steps in this section in order to reset an AP 350 that runs Cisco IOS Software.
Note: Cisco IOS Software-based APs have a default configuration that includes a username and password combination. Both the username and password are "Cisco", which is case-sensitive. After you reset to factory defaults, be prepared to give "Cisco" as both the username and password when you are prompted by either the GUI or the CLI.
The AP350 does not have a MODE button to reset the AP to factory defaults. So, if neither the GUI or CLI is available with sufficient privileges in the AP350, complete these steps to delete the current configuration and return all access point settings to the factory defaults using the CLI.
Reboot the access point by removing power and reapplying power. Let the access point boot until the command prompt appears and the access point begins to inflate the image. When you see these lines on the CLI, press ESC: Loading "flash:/" ...########################################################################### ################################################################################ ################################################################################ ####################
Once you press ESC, this information is displayed on the CLI screen..
Xmodem file system is available.
flashfs[0]: filesystem check interrupted!
The system has been interrupted, or encountered an error
during initialization of the flash filesystem. The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
flash_init
ether_init
tftp_init
boot
ap:
At the ap: prompt, issue the flash_init command.
ap: flash_init
Initializing Flash...
flashfs[0]: 142 files, 6 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7612416
flashfs[0]: Bytes used: 3407360
flashfs[0]: Bytes available: 4205056
flashfs[0]: flashfs fsck took 0 seconds.
...done initializing Flash.
Issue the dir flash: command in order to view the contents of Flash, and find the config.txt configuration file.
ap: dir flash:
Directory of flash:/
3 -rwx 223 env_vars
4 -rwx 2190 config.txt
5 -rwx 27 private-config
150 drwx 320 c350-k9w7-mx.122-13.JA
4207616 bytes available (3404800 bytes used)
Rename the config.txt file to config.old.
ap: rename flash:config.txt flash:config.old
Issue the reset command in order to reboot the 350.
ap: reset
Are you sure you want to reset the system (y/n)?y
System resetting..Xmodem file system is available.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:40:96:41:e4:df
Loading "flash:/c350-k9w7-mx.122-13.JA/c350-k9w7-mx.122-13.JA"...########
Note: The AP is configured with the factory default values that include:
The IP address, which is set to receive an IP address with DHCP
The default username and password, "Cisco"
After the full Cisco IOS Software is loaded and connectivity is reestablished, delete the config.old file from Flash.
Issue the del flash:config.old Cisco IOS Software command at an enabled prompt from the CLI.
ap#del flash:config.old
Delete filename [config.old]
Delete flash:config.old [confirm]
ap#
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_password_recovery09186a00800949d0.shtml#res350ios
Hope this helps!
Rob
Yes very much, I got it to reset. I am now on the hunt for the win 2k/XP drivers so I can use the GUI to configure it.
You have just saved me a bunch of frustration, now I don't have to call anyone about it!
Thanks again
Joshua
using tftp program from solorwinds. and I am having a tough time with getting it to upload the image. should I rename the image from a .img to a .cfg and use the Cisco CAC tool?
