Aironet Air-AP1041N-E-K9 to work with controller
sefimizra
Hi all,
Can I configure Aironet Air-AP1041N-E-K9 to work with controller?
Sefi
Scott Fella
You can, but you first need to convert the ap to lightweight mode which requires you to be able to download the image. This does require you to have a valid support contract in order to access the image download. Then you also need to have the correct code on the controller. Here is a matrix that shows you what is supported on what code:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Here is how to covert the access point to lightweight and vice versa:
-Scott
-Scott
Hi Scott,
Thanks for your answer but all the links you put here talking about the opposite way (to convert from Lightweight to autonomous AP) and some of the links don't work.
Is there away to do what I asked?
Sefi
The conversion works both ways. There are many docs out their on this. Just search for lightweight to autonomous.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101110.html#ID1111
http://m.youtube.com/watch?v=Fiv76UpStKI
https://supportforums.cisco.com/video/11928901/lwapp-lightweight-mode-autonomous-conversion-and-vice-versa
-Scott
-Scott
