Aironet outdoor wireless devices user limitation
abid.salehy
Hello everyone !
Is there any user limitation within Aironet outdoor wirless devices and indoor access points ?
mohib
5 Replies 5
Scott Fella
Typically the outdoor AP's have a bigger range of temperature operating range. Also the TX power varies for bridge and access point for outdoor due to federal regulations. All this information can be found in the AP's data sheet. Indoor AP's should not be used if the antenna has line of sight to the sky without any walls, because that's what determines indoor vs outdoor regulations.
Hope that helps a bit.
-Scott
-Scott
thank you scott fella
would you please help me about the user limitations for the outdoor access points ?
There really is no user limitations.  Your design will depict what your limitation would be overall.
-Scott
-Scott
Thank you Scott Fella !
No problem.  Just remember to review the capabilities of the AP's from the data sheet.  You can also reach out to your Cisco SE or a Cisco Partner in regards to the best model to purchase for your design.
-Scott
*** Please rate helpful post ***
-Scott
