Single vWLC with DHCP scopes for multiple locations
Adam Hudson
I'm in the middle of configuring my vWLC, specifically DHCP. I have four different locations with different DHCP scopes for each location. Is there a way to configure the vWLC with different "sites" so I can point to different DHCP scopes depending on what "site" the APs are configured for?
Scott Fella
Adam,
Can you explain in more detail or have some examples?  There are various ways of possibly achieving what you want, using ip helpers if local switching is used or if the WLC will be the dhcp, for central switching, you can use AP Groups and map the specific WLAN to an interface.
-Scott
-Scott
