AirOS 3504 WLC System and Alarm LED blinking amber and orange
Hello everyone,
I have a customer that has a 3504 WLCs in HA. The Active WLC has made 2 failovers in less than a week and the System and Alarm LED are blinking orange/Amber.
Acording to Cisco WLC 3504 Release 8.5 Deployment Guide, this is an Internal voltage Error
My question then, Is this something that can be fixed, or is this something that can only be handled with an RMA?
marce1000
 - RMA is the only option,
 M.
RxTx
HW fault... you can try replace the power source and check/replace the capacitors inside if you can't RMA.
marce1000
 M.
