SSID stopped broadcasting
Mash.zafar.1
Community Member
Hi All,
Can any one guide me what  i am doing wrong here. I am trying to enable web auth on my one SSID and followed all the steps carefully to enable it correctly. But as i enable the option of web auth in layer 3 option in WLC i noticed that AP stopped to broadcast my that SSID on which i enabled Web auth. Please guide me further to make it right.
Mash.Zafar
17 Replies 17
ammahend
whats the controller model/version, paste the running config of current non working configuration.
-hope this helps-
Hi ammahend,
Controller model is 9800 and version is 17.9 and i have also attached the config file.
Mash.Zafar
Mark Elsen
 - Have a checkup of the 9800 controller configuration with the CLI command show tech wireless ; feed the output into
        Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi marce,
What should i check in controller configuration it is new controller i am deploying it first time.
Mash.Zafar
JPavonM
First of all do not use default configs, on this case for aaa methods.
Second, do not use 1.1.1. as virtual IP as this is assigned to cloudflare and use TEST subnets covered on RFC5735 (https://www.rfc-editor.org/rfc/rfc5735)
Hi Pavon,
I have also tried doing it by making new profiles but still it showing same behavior. I can't understand just enabling web auth feature from WLC to specfic SSID stops it broadcasting when i turned it off it again starts to broadcast.
Mash.Zafar
Hi Pavon,
Please note that the clients to authenticate using the wlc guest portal need to authenticate centrally.
So go to policy and enable Central authentication. See the screenshot below
bonjour,j'ai le méme soucis moi aussi maintenant et pour cela jai accédé à ce site,est ce que tu as trouvé la solution?
@DDMSupport please start a new thread explaining exactly what your problem is in detail including:
- WLC model?
- Software version?
- AP model?
- WLAN and profile policy config?
- AP in Local Mode or Flexconnect mode?
- What troubleshooting and debugging has been done?
Take note of TAC recommended code versions (link below)
Check your WLC config using the Config Analyzer (link below)
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
you want WebAuth local or external ?
Thanks A Lot
MHM
Hi MHM,
Yes Web Auth local by making guest users on WLC.
Mashaheer Zafar
Which guide you follow  can ypu share link.
Thanks A Lot
MHM
Hi MHM,
I followed the instruction video.
Mash. Zafar
I want to check video to see missing steps
Thanks A Lot
MHM
