All clients on network using only 802.11a and g but no n?
Wil Cha
Controller - WISM
AP - 1142
Clients - various apple and computer (802.11n capable)
Hi all,
I have a strange issue in my wireless network whereby all clients are associating to the network on 802.11a and 802.11g only. No clients are using 802.11n when there are capable. Other ap groups on this wism controller are working fine with all clients using a/n or b/g/n but this particular ap group does not seem to work. I've checked the wlan and ap group config/template multiple times and refreshed the template out to the site but appears the every single client is still connecting via a or g.
802.11n is definitely backwards compatible! Does anyone have any idea what this could be and perhaps where I should look for configuration errors?
Many thanks again.
Wil
Sandeep Choudhary
Hi Wilton,
Please check the followings :
1. WLAN is WMM enabled
2. Security must be WPA2+AES or Open
(If you dont meet these 2 requirements you wont be able to push HT rates)
3. 802.11n Rates and support should be enabled on the network (a or b/g)
4. Max data rates without 40 Mhz will be 150  and with 40 Mhz will be 300
5. To verify please issue the command on the AP "show controller d1"
Dont forget to rate helpful posts
Sandeep Choudhary
Hi Wilton,
WMM! that was disabled!
Thanks for the quick responce. I
Glad that worked.
Thanks for rating Wilton.
Reagrds
