CAP1552E with CT5508
Debudas123
      i have 12 nos CAP3602I, 4 nos of CAP1552E and CT5508 , i have added all the indoor caps (3602I) in controller, but outdoor caps (1552E) are not adding, so anyone please help me.
thanks
Debu
34 Replies 34
Scott Fella
For MESH AP's you need to add the Ethernet MAC address to the Mac filter on the WLC. This is a requirement.
-Scott
i have done, but its not showing in ap list, another thing is that when i will try to configure the caps through console its configured and ssid's also broadcasting, and its working like standalone ap.
thanks
debu
Scott Fella
Please refer to this guide, adding the Mac filter.
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.4/design/guide/mesh74_chapter_0101.html#ID4807
-Scott
Scott Fella
Here is a link specific to the 1552 which you have, but they are all the same. The mesh will not join unless you add the Mesh AP's MAC address to the WLC.
http://www.cisco.com/en/US/docs/wireless/access_point/1550/quick/guide/ap1550qsg.html#wp45556
-Scott
Sandeep Choudhary
HI Debu,
Can you paste the output of these commands:
From WLC: sh sysinfo
From AP: sh vrsion
Also console to AP and paste the entire bootproess here.
For mesh AP: Dont forget to add MAC address in mac filter list.
Security > AAA > Mac Filter then add the mac of AP here.
Reagrds
Dont forget to rate helpful posts.
se the following details
from WLC
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.121.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... Cisco_db:47:84
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.10.3.2
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 17 mins 32 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... IN  - India
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 78:DA:6E:DB:47:80
Power Supply 1................................... Present, Power Off, Fan On
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 25
(Cisco Controller) >
from AP
sho version
Cisco IOS Software, C1550 Software (C1520-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 05:12 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
ap uptime is 7 minutes
System returned to ROM by power source change
System image file is "flash:/c1520-k9w7-mx.152-2.JB/c1520-k9w7-xx.152-2.JB"
Last reload reason:
--More--                           agree to comply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1552E-N-K9    (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1802P1HT
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power source change
AVR Microcontroller 1 - SW Version: 00.01.02
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:95:F3:8A:26:E0
Part Number                          : 73-13538-02
--More--                           PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC17207LNQ
Top Assembly Part Number             : 800-34851-05
Top Assembly Serial Number           : FTX1802P1HT
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-N-K9
Configuration register is 0xF
ap#
thanks
Debu
HI Debu,
Last reload reason:
As per your post , you have autonomous image on WLC and you need lighweight image to connect to a WLC:
Following are the three type of IOS available & need to download the correct type before starting the conversion process.
  • k9w7 – autonomous IOS
  • k9w8 – full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on “mesh” APs)
  • rcvk9w8 –  lightweight recovery image – this is factory installed on lightweight  APs, unless a “mesh” image is specified; it lacks radio firmware
For the LWAP conversion, use the recovery image ( e.g  c1140-rcvk9w8-tar.124-25d.JAL.tar). We can use the same command on the autonomous AP priviledge mode.
AP5475.d0f5.2ee7#archive download-sw /force-reload /overwrite tftp://IP/xyz-rcvk9w8-tar.......tar
check this link for help:
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Scott Fella
You have an autonomous AP
You need to download a lightweight image.
-Scott
Scott Fella
You can download the software here.
c1520-k9w8-tar.152-4.JB3.tar
http://software.cisco.com/download/release.html?mdfid=283791419&flowid=24862&softwareid=280775090&release=15.2.4-JB3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
K9w7 is autonomous
K9w8 is lightweight
Ways to convert autonomous to lightweight and vice versa. Might be east for you to do the archive download command.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
Scott Fella
Archive download.... Support doc
-Scott
after upgrading the firmware, one cap's connected okay, but rest of three showing the error, i hav ementioned following
AP189c.5d8f.e080#
*Feb 11 12:15:42.099: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 11 12:16:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.10.3.2 peer_port: 5246
*Feb 11 12:16:34.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_
dtls_connection_db.c:2051 Max retransmission count reached!
*Feb 11 12:17:04.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
10.3.2:5246
*Feb 11 12:17:04.999: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 11 12:16:24.899: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Feb 11 12:16:24.899: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Feb 11 12:16:24.899: %MESH-6-LINK_UPDOWN: Mesh station 189c.5d8f.e09c link Down
what i will do ..
thanks
Debu
HI debu,
Add the MAC address of the MAP to the MAC filter table. In order to do this, choose
securiyt > AAA > Mac Filtering > Mac Address
Reagrds
already added
thanks
Debu
HI Debu,
Something is blocking.....
because AP is getting IP and you can ping the WLC. AP fails to join means that UDP 5246 and or UDP 5247 is being blocked.
If still fails then factory reset the AP with mode buuton
Resetting to Default Settings Using the MODE Button
Follow these steps to reset the access point to factory default settings using the access point MODE button:
Step 1Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point
Step 2 Press and hold the MODE button while you reconnect power to the access point.
Step 3 Hold  the MODE button until the Status LED turns amber (approximately 1 to 2  seconds), and release the button. All access point settings return to  factory defaults.
follow this posts:
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
If still faile then paste the full logs from console of AP.
Reagrds
