Anchor Controller in different Mobility Group
dne222
Level 2
Level 2
is there a way to use a DMZ WLC to use the guest access even if the DMZ WLC is not in the same mobility group as the internal WLCs are ? Has there to be a mobility group over all WLCs that this can be handeld ?
Thanks Dennis
Scott Fella
The DMZ WLC's should be on a different mobility group than the foreign WLC's. Will it work either way.... yes.
-Scott
