anchor controller in DMZ
Rik19972000
I wondering which vlans need to be allowed over the trunk.
Management vlan
Vlan towards internet
I'm wondering via which vlan the EoIP tunnel is setted up?
I also suppose for AP-manager, I can use a useless random IP?
weterry
Level 4
Level 4
Both mobility tunnels are done from management IP to management IP. You are correct about the AP-Manager, no APs should be connecting to the DMZ so any address should work.
Trunk should consist of whatever vlans you have defined on the controller.
