03-27-2013 12:39 AM - edited 07-03-2021 11:47 PM
1410 x 4
sector antenna x 4
three sites.... two root bridges on tope of hq, and two non-root bridges one for each remote sites
root1 -> remote site 1 (3km)
root2 -> remote site 2 (1.5km)
the above mentioned setup is working fine.
to save one ap+antennax2, replaced one sector with an omni.
so, now...
1410 x 3
omni x 1 (headquarters) part# AIR-ANT58G9VOA-N
sector x 2 (remote sites)
root1 -> remote site 2 (1.5)
upon replacing the root bridge antenna from sector to omni, the following occured:
1. lost connection between root bridge and the switch.
2. show cdp on switch will not show the bridge.
3. show cdp on bridge will not show the switch.
4. switchport status is up and led is lit normal.
5. connecting to the root bridge... connection to the remote bridge is ok, remote bridge is associated and pingable. but after a while connection will be lost.
6. a bridge power reset will restore the connection but the problem will come again after some time. with power reset i'm unable to see the logs.
7. some times an hour, and sometimes after 10 - 12 hours before the problem occurrs again.
8. installed the omni antenna upward, on top of pole... same problem.
9. installed the omni downward (close to pole)... same probem.
10. installed the omni downward (away from pole with 0.5m metal arm)... same problem.
11. replaced the power injector... same problem.
12. replaced the patch cord from root bridge to switch.... this lasted for more than 12 hours and the problem came back.
13. switch show log only show that there has been a switchport reset on the port where the root bridge is connected.
14.
what coudl be the problem here.
thanks, experts!
03-27-2013 01:43 AM
Can you please give us some more info so we get better understanding.
- If sector antenna are working fine then why to replace one of them?
- Why using sector antenna? why not directional antennas?
- Provide - if possible - a simple sketch about how your bridges are connected ( I currently imagine that the HQ is in the middle and there is one root bridge on each side of it one bridge communicates with another non-root bridge and all 3 buildings are -almost- on straight ilne).
- What vendor/model of sector antennas you use?
I would say seeing the switchport issue is not normal. The bridge should not normally disappear from the switch port.
What I suggest is to upgrade the IOS if it is not already on lates version (read the release notes of the newer release before using it to upgrade).
Amjad
Rating useful replies is more useful than saying "Thank you"
