Anntena for Cisco 1240G A.P.
moabdallah
Does the 1240G AIR-AP1242AG-E-K9 ( 802.11a/g Non-modular IOS AP; RP-TNC; ETSI Cnfg) ship with Anntena ? OR Do I need to order the Anntena separetly ?
Mohamed
Hi Mohamed,
You are most welcome!
You will not need to order any additional Radio module as this AP comes with dual a/g radios buildt-in.
Dual 802.11a and 802.11g radios deliver a combined capacity of 108 Mbps, meeting the performance requirements of the most demanding applications, while hardware-assisted AES encryption provides uncompromised support for interoperable IEEE 802.11i and WPA2 security. A key component of a unified wired and wireless network, the Cisco Aironet 1240AG Series supports Cisco IOS Software and can operate as an autonomous access point or a lightweight access point.
So you should be good to go.
Hope this helps!
Rob
Please remember to rate helpful posts........
11 Replies 11
scottmac
Level 10
Level 10
You need to order the antennas separately. Because of the many roles and installation options supported, the antennas need to be ordered for you specific implementation.
The "usual" 2.2db "rubber ducks" used for general AP implementations are ~US$28.00 each at full retail price.
Good Luck
Scott
Hi Scott,
Thanks for your reply
I am going to use the 1240G in-door access point to support 802.11 a/b/g
Which Anttena should I order ? What is the part number ?
Mohamed
Rob Huffman
Hi Mohamed,
As Scott indicated in his post, there are many different Antennas that can be used with the 1200 Series AP. Have a look at this good reference guide that includes Part numbers etc. Hopefully this will help you decide on what antenna is best suited for your environment;
Cisco Aironet 1200 Series
Cisco Aironet Antenna Reference Guide
This antenna reference guide is intended to provide information to assist in understanding the issues and concerns of antennas used with a Cisco® Aironet® wireless LAN system, or wireless bridge system. It details deployment and design, limitations and capabilities, and basic theories of antennas. This document also contains information about the Cisco Systems® antennas and accessories, as well as installation scenarios, regulatory information, and technical specifications and diagrams of the available antennas.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet09186a008008883b.html
Hope this helps!
Rob
Please remember to rate helpful posts..........
Hi Rob,
AS I understand, Each Access Point (indoor) AIR-AP1242AG-E-K9 (802.11a/g Non-modular IOS AP; RP-TNC; ETSI Cnfg) will need (2) AIR-ANT4941 2.4 GHz,2.2 dBi Dipole Antenna w/ RP-TNC Connect AND (2) AIR-ANT5135D-R 5GHz 3.5dBi Dipole Antenna w/RP-TNC connector
Is this correct ? each unit will need (2) AIR-ANT4941 & (2) AIR-ANT5135D-R to work 802.11a/g ?
Mohamed
Mohamed,
Be advised that the 1240 requires external 802.11a antannas (as opposed to the integrated RM-21A antenna in the 1232). As a result not all channels run at full power, since they have to take into account higher gain antennas (>9dBi) that may be externally connected. More than half of the current 12 channels can only run at half or quarter the full transmit power allowed in the 5Ghz bands.
Rob Huffman
Hi Mohamed,
Yes the antennas you referenced will work with the 1240 series a/g.These 2 that you have chosen are probably a good economical place to start. Go with 2 of each as stated in your previous post for the maximum coverage from this style.Have a look;
Dual RP-TNC Antenna Connectors for Both 2.4-GHz and 5-GHz Radios Antenna connectors support a variety of Cisco 2.4-GHz and 5-GHz antennas, providing range and coverage versatility.
From this doc;
http://www.cisco.com/en/US/products/ps6521/products_data_sheet0900aecd8031c844.html
Here is a look at the antennas you have chosen;
Cisco Aironet 2.4 GHz Articulated Dipole Antenna (AIR-ANT4941)
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a0080161677.html
Cisco Aironet 3.5-dBi Articulated Dipole Antenna (AIR-ANT5135D-R)
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a0080338828.html
Hope this helps!
Rob
Hi Rob,
Do I need two AIR-ANT4941 and two AIR-ANT5135D-R
OR
one AIR-ANT4941 and one AIR-ANT5135D-R ??
Mohamed
Hi Rob,
Thanks for your help
I will get (1) AIR-AP1242AG-E-K9, (2) AIR-ANT4941 and (2) AIR-ANT5135D-R
Do I need to order any other part number ?
Do I need to order Radio module ?
Mohamed
Hi Mohamed,
Hope this helps!
Rob
Hi Rob,
What about the AP 1230G ?
Do I need also to order the Antenna separetly ?
What is the difference between 1231G and 1232G ?
"AIR-AP1231G-E-K9" 802.11g IOS AP w/Avail CBus Slot, ETSI Cnfg AND "AIR-AP1232AG-E-K9" 802.11a/g dual radio IOS AP, ETSI cfg ?
Mohamed
Hi Mohamed,
The difference in the 2 AP's that you have listed is that the 1231G-EK9 will only come with a G radio with the ability to add an A radio at a later time and would require external antennas(2). The 1232AG-E-K9 would come with A&G radios and would also require external antennas (4). Have a look at these docs;
The mini-PCI interface supports either an 802.11b or 802.11g radio operating in the 2.4 GHz frequency band.The CardBus interface supports an 802.11a radio operating in the 5 GHz frequency band. At least one radio must be installed for the AP to operate in a Wireless LAN, and at most two radios (one of each form factor) can be installed.
2.4 GHz antennas are not included with the 802.11g radio module; they must be identified under a separate order line item and purchased separately. There are two versions of the 802.11a radio modules. The 802.11a RM21A radio module(**not what you have listed**) is designed with integrated antennas; therefore, no antenna selection is required. The 802.11a RM22A radio module, however, has dual RP-TNC antenna connectors. Auxiliary 5 GHz antennas are not included and should be ordered separately.
Preconfigured Bundle
Platform
Radio Module
Regulatory Domains*
AIR-AP1231G-x-K9 AIR-AP1210 AIR-MP21G x = A, E, or J
AIR-LAP1231G-x-K9 AIR-AP1210 AIR-MP21G x = A, E, or J
AIR-AP1232AG-x-K9 AIR-AP1210 AIR-MP21G and AIR-RM22A x = A, C, E, I, J, K, N, P, S, or T
AIR-LAP1232AG-x-K9 AIR-AP1210 AIR-MP21G and AIR-RM22A x = A, C, E, I, J, K, N, P, S, or T
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet0900aecd801b91d4.html
ANTENNAS
The 802.11g modules of the Cisco Aironet 1230AG Series support a flexible set of Cisco Aironet omnidirectional and directional antennas that can be mounted on walls, ceilings, or masts. The 802.11g radios do not come with antennas-they must be ordered separately. Similarly, the 802.11a radios do not come with antennas. Auxiliary 5 GHz antennas are required and should be ordered separately. Cisco Aironet 1230AG Series access points are certified for operation only with Cisco Aironet antennas. To ensure regulatory compliance, select Cisco Aironet antennas for use with Cisco 1200 Series access points.
From this doc;
http://www.cisco.com/en/US/products/ps6108/products_data_sheet0900aecd801b9266.html
A complete Antenna Reference Guide is available to assist users in selecting the proper antenna for specific deployment requirements:
http://www.cisco.com/warp/public/cc/pd/witc/ao350ap/prodlit/agder_rg.htm
Hope this helps!
Rob
