Anser incomming call on 7920
qbui
Level 4
Level 4
I seem can't answer the incomming calls on my 7920 phones. The phones ring but I just can't answer. The green botton won't do anything. I can place the calls fine.
Does anyone have any idea ?
a-vazquez
Level 6
Level 6
The problem can be analysed in two ways.
1. WiFi - wireless side
2. 7920 Phone side
Check the wireless side also for this.
Thanks for the input.
I already fingured out that it was firewall problem. CCO seems to says fixup h323 should work for voip through the PIX but it doesn't and that was my scenario CCM ( + ip phones ) -- PIX -- 7920.
Outbound call from inside phones to 7920 doen't work.
