Antenna for 350 Accesspoint
arraman
I have a 350 wireless bridge with metal case...i need to use it as accesspoint for internal purpose. can anyone suggest which antenna should be suitable for implementing indoor and coverage around 500sq. feet is enough
thanks
Arun
a-cardenas
I suggest you use this antenna
AIR-ANT1728 2.4 GHz, 5.2 dBi Ceiling Omni Ant. w/RP-TNC Connector
personel I have very good result.
