ANT2566D4M-RS antenna and warehouse
iores
what it is your experience with this antenna in warehouse environment especially for areas between racks? What else did you used it for?
How do you choose antenna based on gain for areas between racks? For example, if this area is 60m or longer, would you go with 13dBi antenna or would you choose ANZ2566D4M-RS?
marce1000
  - Review this article : https://lwcom.ae/blog/wireless-network-at-a-warehouse-or-it-s-not-as-simple-as-it-seems/
    The particular antenna type (ANT2566D4M-RS is mentioned too ; use Find with you browser and 'read around'.....
 M.
@marce1000
I know about this article. However, I wanted to hear reasoning why to choose this antenna over one with gain of 13dBi, for example.
Leo Laohoo
Get a wireless placement design done by a professional because the software they use can mate an AP to the appropriate WiFi antenna based upon the layout of the racks.
Haydn Andrews
Have used this Antenna between aisles. Each warehouse has been different, I have generally gone with 2 of them pointing from each end and it will cover the 60m, that being said I always do a site survey to confirm
*****Help out other by using the rating system and marking answered questions as "Answered"*****
