Antenna Alignment - AP1572EAC
martynch1
Level 4
Level 4
We have had an AIR-AP1572EAC-E-K9 installed by a 3rd party but unsure if the alignment is as true as it could be, I’ve been searching Cisco with no luck on how to make sure that these are aligned as good as they can be.
Is there a tool that we can use to align such as an audible tone, if not what is the best way to align bridges.
Martyn
patoberli
It actually depends on the antenna you use.
So without knowing that detail, I can't really help you.
This document should help you: https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
