Antenna - Connected ?
zirbo
Is there a way to tell remotely if an antenna has been connected to a specific radio interface (just as you are able to see a serial cable connected to a serial interface) ?
Thank You,
Dragos
scottmac
Level 11
Level 11
(Assuming you mean a couple autonomous APs versus several APs connected in a LWAPP system).
Aside from looking for the RSSI (Signal Strength indicators) and making an educated guess, I'm pretty sure there's not.
Good Luck
Scott
Scott Fella
Well if they are 1242 ap's, the b/g side is where the console and ethernet goes, a is on the other side and is closer together. Is this what you are looking for?
-Scott
Not really - I am looking for a "show *" way of telling remotely wether any antenna has been connected to the antenna port. I am not trying to locally identify the physical ports available on the access point.
Dragos
