ping issue on WLAN
wingu
Community Member
I'm using AIR-AP1232AG.
I did ping test to gateway and the result is not so good like below.
What should I do for this?
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 10.1.1.1: bytes=32 time=1ms TTL=255
Reply from 10.1.1.1: bytes=32 time=2ms TTL=255
Request timed out.
Reply from 10.1.1.1: bytes=32 time=9ms TTL=255
Reply from 10.1.1.1: bytes=32 time=15ms TTL=255
Reply from 10.1.1.1: bytes=32 time=10ms TTL=255
Request timed out.
Request timed out.
Reply from 10.1.1.1: bytes=32 time=7ms TTL=255
0 Replies 0
