Antenna gain of a 3502AGN AP
patoberli
Hello
I recently checked the output of one of my AP 3502AGN which are connected to a WiSM with the current 7.0.240.0 software.
There I saw the following output:
show ap config 802.11b 3502AGN-1100c-1
      Legacy Tx Beamforming ..................... ENABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
As you can see the antenna gain is set to 8 for the internal antenna. The Data Sheet tells me it should be 4 dBi for the 802.11b band:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10981/data_sheet_c78-594630.html
Is that a bug of the current firmware?
I have the feeling that the signal coverage isn't anymore as good as it once was, but that can also just be my imagination.
Maybe somebody can shed some light onto this.
Patrick
Leo Laohoo
No.  Did you see it states "in 0.5 dBi units"?  So this means you need to multiply by 0.5.
Leo Laohoo
Ah that's what that means
I thought that means that also 0.5, 1.0, 1.5, ... is allowed and not only 1.0, 2.0, 3.0, ...
Ok then everything is clear.
Thanks for taking the time to rate the posts.
