Antenna Polarization
kfarrington
Level 7
Level 7
Hi Guys,
I have two cisco docs here for two different Antennas.  The 5959 states Vetical Liniear and the 5145 does not state vertical or horizontal.  Why is this? And does it matter?
AIR5959
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a008007f904.html
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant545r.html
AIR5145r
Many thx
Ken
Elliott Shawd
Level 5
Level 5
It shows you the propagation for the E and H plane or whatever. The one on the left is the horizontal propagation, I'm pretty sure, so it seems you should mount it horizontally. That's the only way I've ever mounted it.
