Wireless access points
samlight1
Community Member
How far can the WAP4410N Access Point be from a router before its signal starts to degrade.  I need an access point that can handle at least 65 feet from a wireless router.  The distance is from building to building.
Elliott Shawd
Level 5
Level 5
You can't be sure until you test. Your best bet is to go with outdoor antennas mounted on the side of each building. Always think "line of sight" when dealing with wireless...
