Antenna Question
smitty6504
Level 4
Level 4
Can i use a B/G rubber duck antenna on an A radio?
Leo Laohoo
Unless you want to burn your radio:  NO
Saurav Lodh
Level 11
Level 11
Antennae should be properly chosen , as you need to take care of impedance match. If mismatch happens the power will reflect back and may damage your device. So careful
