Antenna question
s.hellman
Level 4
Level 4
We are planning to install WiFi in a theater. It is about 6-7 meters to the ceiling and about 500 seats.
We are considering six AP 2802E with external antennas mounted in the ceiling, facing down and a few degrees to the back of the theater. Three antennas in a line at the front and three antennas in a line in the middle.
Is the antenna "AIR-ANT2566P4W-R 2.4-GHz/5-GHz MIMO 4-Element Patch Antenna" a good choice? Is it suitable for AP 2802E and an installation like this?
0 Replies 0
