Antenna Radiation Pattern Concern
darkmagex
Community Member
We currently have a 1200 series with a AIR-ANT2506 covering a mid size area outdoors. We are looking to  be able to connect to a new 1300 bridge that is slightly too far for the  current antenna, we were considering replacing with a AIR-ANT24120 but the 7 degree vertical plane is concerning.
The antenna is mounted on rooftop and the concern is the signal may be weak on the ground do to the low vertical plane. Is this a valid concern, I'm still working through my understanding of radiation patterns.
Roman Rodichev
Level 11
Level 11
If you get a bad signal, find a way to tilt the antenna.
Vinay Sharma
Level 8
Level 8
check this
"Best Practices" for positioning Access Points (AP's) and Antennas
https://supportforums.cisco.com/docs/DOC-16627
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
Thanks & Regards
Saurav Lodh
Level 11
Level 11
