Antenna Usage Advise
n-khouri
Can I use the 2.4 GHz,12 dBi Omni Mast Mt. Antenna w/RP-TNC Connector on AP 350 to communicate with client adpaters with 2.2 DBI integrated antenna within an outdoor area of 200m*300M ?
I will do the survey if it is valid.
scottmac
Level 10
Level 10
It should be ok, assuming clear line-of-sight, and the distance of coax feeding the 12dbi omni (mast) isn't too long.
Good Luck
Scott
