Aolabi
Aolabi201
Community Member
Hi every one I have here Cisco Aironet 3700 I need to create ip default-gateway for Dhcp server But I do not know Can anyone help me i have here error message
Freerk Terpstra
Level 11
Level 11
What is your idea by configuring the "default gateway"? From your pictures I can determine that you have a 3700 controller based access-point without any antennas. If you want to use this access-point you will need some antenna's and a WLC (or you have to manually convert it to a autonomous access-point by changing the software).
If you want your access-point to join a existing WLC you need to understand the access-point discovery process.
Freerk Terpstra Thank you for answeer me
i have 4 antennas but I'm not that they need now i need just to fix the error messeage
