1532 AP - no response using 5GHZ Radio WorkGroup Bridge
roger perkin
Level 2
Level 2
I have configured a 1532 AP in Autonomous Mode as a Workgroup Bridge.
It is working perfectly using the 2.4ghz radio but when I try the 5ghz radio I get an error
Cannot associate - no response.
I have 4 antennas connected into all the external connectors.
Working config
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm
 ssid TEST
 speed  basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role workgroup-bridge
 bridge-group 1
When I move the config to the Dot11Radio 1 I get cannot associate errors
Has anyone faced any issues with 5ghz radios on a 1532 AP running in Autonomous mode?
The status of the interface is reset ?
roger
abwahid
Level 4
Level 4
Can you please share the error message screen shot or logs..so we may easily drill down and rectify the issue..
