AP 1240 Fallback problem
anix
Community Member
I have a problem with Fallback configuration on AP 1240. In the manual 12.3(8)JA I found that there is possible to configure fallback wthen AP lost connection in RadioA, but when I go to int d0, there is only Reapeter and Shutdown, no Tracking like in the manual (page 138).
Could you help me with that.
jwadleigh
Level 3
Level 3
Hi, Anix. Check out the IOS Reference:
http://www.cisco.com/en/US/products/hw/routers/ps272/products_technical_reference_chapter09186a008022e0e3.html#wp2647917
The command for configuring fallback on a 1240 is copied below:
station-role
Use the station-role configuration interface command to set the role of the radio interface. Use the no form of the command to reset the parameter to the default value.
1200 and 1240AG Series Access Points
station-role
{non-root [bridge [wireless-clients] | wireless clients] |
repeater |
root [access-point [fallback {shutdown | repeater}] | ap-only] |
root [bridge [wireless-clients]] |
scanner |
workgroup-bridge}
I hope this helps!
