AP 1250 does not work
Good Day,
We have a controller AIR-WLC2112-K9 and AP AIR-LAP1252AG-N-K9, and one AP does not work, send this combination:
Amber (ethernet)      OFF (status)     Green (radio)
I serch in Troubleshooting 1250 Series Lightweight Access Points, and this combination does not appear.
when trying to connect through the console port I get nothing, anyone know how to solve this error?
Rasika Nayanajith
Did you check your terminal settings? Does it work with any other device console output?
The terminal setting:
Bits/sec     9600
Bits/data    8
parity          None
stop bits     1
flow control  nove
When connect other device console port work fine.
