AP 1552 in Mesh mode (MAP)
EvaldasOu
Level 4
Level 4
Hi guys!
I'm trying to become famillar with Cisco Mesh AP's deployment. As I know RAP's (Roof-top AP's are AP's with Ethernet/Fiber connection to the network). I connected these AP's via L2 switch , they can reach WLC and everything looks fine.
No I want to connect few MAP's to my RAP's. But of course firstly we will need to set-up IP addresses for these MAP's? But how? There is no "configure terminal" option at all ( on mesh AP console) .
MeshAP#?
Exec commands:
  access-profile   Apply user-profile to interface
  capwap           capwap exec commands
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  dot1x            IEEE 802.1X Exec Commands
  eap              EAP Exec Commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  logging          Handles logging operations
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapconfig       OfficeExtend AP configurations
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  partition        Partition disk
  ping             Send echo messages
  pwd              Display current working directory
  radius           radius exec commands
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  rsh              Execute a remote command
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  ssh              Open a secure shell client connection
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade commands
  verify           Verify a file
  where            List active connections
Should I use DHCP server and connect these AP's via Ethernet/Fiber connection somewhere also?
Thank you for your time and for your answers.
21 Replies 21
That is correct. How many are you trying to connect. Maybe try one at a time. I didn't put the antennas on when I staged the APs either.
-Scott
Take a look at the logs from the wlc and the console to.
-Scott
Mhm, I'm using now one RAP and tow MAP's . All the information that I see in WLC logs is related just with physical AP (RAP).
Console into the map. Also the guide has some debugs commands you can run.
-Scott
Scott Fella
Try to hard set the channel on the rap.
-Scott
I tried it also Scott. Looks like everything what I needed to do there was to attach external antennas for these AP's.
I just wanted to hide from a big radiation
Everything works now. MAP's associated to the RAP, and the other RAP's (which are not connected via ethernet at this moment) also connected to the RAP. I can see everything on the WLC
Thank you Scott once again!
No problem. At least you have it working.
-Scott
