AP 1552 in Mesh mode (MAP)
EvaldasOu
Level 4
Level 4
Hi guys!
I'm trying to become famillar with Cisco Mesh AP's deployment. As I know RAP's (Roof-top AP's are AP's with Ethernet/Fiber connection to the network). I connected these AP's via L2 switch , they can reach WLC and everything looks fine.
No I want to connect few MAP's to my RAP's. But of course firstly we will need to set-up IP addresses for these MAP's? But how? There is no "configure terminal" option at all ( on mesh AP console) .
MeshAP#?
Exec commands:
  access-profile   Apply user-profile to interface
  capwap           capwap exec commands
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  dot1x            IEEE 802.1X Exec Commands
  eap              EAP Exec Commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  logging          Handles logging operations
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapconfig       OfficeExtend AP configurations
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  partition        Partition disk
  ping             Send echo messages
  pwd              Display current working directory
  radius           radius exec commands
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  rsh              Execute a remote command
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  ssh              Open a secure shell client connection
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade commands
  verify           Verify a file
  where            List active connections
Should I use DHCP server and connect these AP's via Ethernet/Fiber connection somewhere also?
Thank you for your time and for your answers.
21 Replies 21
Scott Fella
When I have a mesh deployment, I always try to stage them just like any other access point.  I would power them up with a power injector or an ac adapter and connect them to a switch and let them join the WLC.  Then I would configure my RAPs and them my MAPs and if you want, set the ip address.  Make sure you set the bridge group name, put the mac address in the mac address filter while you are staging them.  Again, this is how I do all my mesh deployments.  Now if they add mesh ap's later, I would still connect them to the network like a regular LAP and have them join the WLC and configure them for either a rap or map.
From the CLI, the command to assign a static is :
capwap ap ip address
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks Scott.
I did everything exactly as you mentioned in your post.
Looks like there is a problem with CAPWAP tunnel for mesh AP's. Maybe the problem is because the time is different on mesh AP's and controller. I'm not using NTP server also.
That is a requirement.... the mesh ap's are just like any other lightweight access points.  Make sure the time is set and make sure the country code is correct.
Scott
-Scott
Okay, AP's are reloading now.
Maybe you also know, is there any difference if we add our AP's MAC addresses to the :
Security -> AAA -> AP Policies or Security -> AAA -> MAC Filtering , lists?
It's the Mac filter list you need to ad the Mac address
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mesh.html#wp1472458
-Scott
Yes, I know. But I think there is no difference in which list will you add the mac address of the AP.
You can add it in AP Policies, or MAC filtering list.
Everything is okay, when I connect AP's to the WLC via Ethernet. When I save all the configuration on MAP's and reload these, they won't connect to the RAP's and to the WLC via Wireless. Time settings also are gone from MAP's. Time settings never be equal without NTP server, if I have a problem because of this, how it would be possible to solve in big mesh AP's deployment?
Well the wlc is the one that need to have the time set. As long as the mac address is in the mac filter list and your bridge group names are fine, the maps should join the rap with no issue. Now how are you powering up the rap and map. A PoE switch will not have enough power to enable the radios. You need to use the power injector for the rap and the AC plug for the maps.
-Scott
Thanks Scott for your time!
Yes, the mac address is in the mac filter list, and bridge group has the same name. Everyting is powered up via AC plug.
I have just one WLAN with WPA2-psk authentication. Does MAP's try to connect to the RAP's via that WLAN?
No it doesn't use your wlan's to connect. What errors do you see in the wlc?
-Scott
Scott Fella
The mac address is the base mac not the radio. Look at the logs on the wlc and see how it's failing.
-Scott
Yes , I'm using base mac addresses also.
Scott Fella
If you followed the guide it's pretty simple. Here is a troubleshooting guide that might help determine the issue you are having.
http://www.cisco.com/en/US/docs/wireless/access_point/1500/troubleshooting/guide/TrbleshtMesh.html
-Scott
Thanks Scott. I don't know maybe the problem is that I'm not using any antennas. RSSI is about -70 for me anyway. Also looks like there is not possible to turn of the AP instantly, because it's using backup battery.
