AP 1572 not joining confroller
calvin216216
Error message received. It tries joining but don't get IP address. then send this error
*Nov 28 12:57:51.535: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_record.c:169 Pkt too old last_seq_num : 1,Received sequence num: 1 distance: 0
Controller Model 5508
Scott Fella
First, make sure the ap is supported on the controller version you are using.  Then review the 1572 install guide for reference.  There are supplemental images you might need along with other requirements like adding the mac address to the controller.  Also search the forum for "1572 not joining controller" for answer and helpful answers.
Solved: AP 1572 not joining WLC - Cisco Community
Cisco Wireless Solutions Software Compatibility Matrix - Cisco
-Scott
Rich R
If it's not getting an IP address then that's a DHCP problem not a controller problem.
First fix the DHCP problem, check switch port config etc.
After the AP gets an IP address then start worrying about joining the controller.  The join is done over IP so no IP = no join!
