01-11-2021 04:27 AM - edited 07-05-2021 12:59 PM
Hello Everybody
I have an Issue with vWLC 8.3 and AP 1602E registration, it gave me the output, is it certificate issue and what shall I do to solve it ?
*Jan 11 11:44:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.14.200.100 peer_port: 5246
*Jan 11 11:45:13.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x7E2528C!
*Jan 11 11:45:43.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.14.200.100:5246
*Jan 11 11:45:44.067: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
Morcos Magdy
01-12-2021 12:17 PM
01-13-2021 02:37 AM
You need to add a country covered by the "E" regulatory domain. You can refer to the following doc:
Wireless LAN Compliance Lookup (cisco.com)
01-13-2021 05:00 AM
tried your solution, Radio Slot# 1 is up now but I can't see the broadcasted SSID
