10-30-2018 07:30 AM - edited 07-05-2021 09:23 AM
Hi everybody!
I have this issue: When I can connect an endpoint to an AP 3800 via 802.1X through ISE without any problem. That works fine.
Then when the user moves to another location, and his notebook connects to another AP (2600 for example) the endpoint keeps his IP configuration but lose his connection with the rest of the LAN. It remains connected, but it can’t reach even his gateway.
This happen everytime that this happen. We think that it could be the 2600 family but we are not really sure about it.... Any suggest?
Thanks!!
10-30-2018 07:40 AM
10-30-2018 10:06 AM
Ok perfect thanks!. Do you move the case? Or I have to do it?
03-23-2019 07:09 AM
Hi Fernando,
Can you check whether the below recommended configuration is present on ur devices?
10-30-2018 10:12 AM
Additional Information:
The WLC has the entry for the PC/Notebook associate to the AP but if you enter to the AP CLI, it doesn't have the Endpoint MAC Address
03-25-2019 03:03 AM
