AP 2800 I can not join AP's to Mobility Express controller
Hello, I have two aps model 2802i, my problem is that my second access point can not to join to mobility express controller, both have the same firmware version 8.10.151.0, When I run a debug command in the controller, I see a error
The IP Address from AP : 10.144.88.162
The IP Address from ME Controller: 10.144.88.24
(Cisco Controller) >
*spamApTask0: Aug 17 07:17:09.351: cc:db:93:79:d7:00 Unable to get Ap mode in Join request
*spamApTask0: Aug 17 07:17:09.353: cc:db:93:79:d7:00 State machine handler: Failed to process msg type = 3 state = 0 from 10.144.88.162:5256
*spamApTask0: Aug 17 07:17:09.353: cc:db:93:79:d7:00 Failed to parse CAPWAP packet from 10.144.88.162:5256
*spamApTask0: Aug 17 07:17:09.353: ÌÛ“y×
*spamApTask0: Aug 17 07:17:09.355: cc:db:93:79:d7:00 Radius Authentication failed. Closing dtls Connection.
*spamApTask0: Aug 17 07:17:09.356: spamSendWlanBwPayloadToTask:AP_DISJOIN_WLAN_BANDWIDTH_RELEASE failed
*spamApTask0: Aug 17 07:17:10.791: 00:00:00:00:00:00 Discarding non-ClientHello Handshake OR DTLS encrypted packet from 10.144.88.162:5256)since DTLS session is not established
From AP console:
[*08/17/2021 17:20:58.3469]
[*08/17/2021 17:21:01.1978] Max retransmission count exceeded, going back to DISCOVER mode.
[*08/17/2021 17:21:01.1978] Dropping msg CAPWAP_CONFIGURATION_STATUS, type = 4, len = 3004, eleLen = 3012, sendSeqNum = 1
[*08/17/2021 17:21:01.2183]
[*08/17/2021 17:21:01.2183] CAPWAP State: DTLS Teardown
[*08/17/2021 17:21:01.2462] echo 34 > /sys/devices/platform/dpapi/port/port_delete
[*08/17/2021 17:21:02.3034] upgrade.sh: Script called with args:[ABORT]
[*08/17/2021 17:21:02.3624] do ABORT, part2 is active part
[*08/17/2021 17:21:02.3862] upgrade.sh: Cleanup tmp files ...
[*08/17/2021 17:21:02.4159] << TLV table entries: 3 for TLV_MOM_TUNNEL_STATUS_PAYLOAD>>
[*08/17/2021 17:21:02.4160] Entry( 0): level 0 type 2371 size 0 value Nested
[*08/17/2021 17:21:02.4160] Entry( 1): level 1 type 1 size 1 value 0
[*08/17/2021 17:21:02.4160] Entry( 2): level 1 type 2 size 1 value 0
[*08/17/2021 17:21:02.4160] << end of the TLV entry table>>
[*08/17/2021 17:21:02.4161] << TLV table entries: 3 for TLV_MOM_TUNNEL_STATUS_PAYLOAD>>
[*08/17/2021 17:21:02.4161] Entry( 0): level 0 type 2371 size 0 value Nested
[*08/17/2021 17:21:02.4161] Entry( 1): level 1 type 1 size 1 value 1
[*08/17/2021 17:21:02.4161] Entry( 2): level 1 type 2 size 1 value 0
[*08/17/2021 17:21:02.4161] << end of the TLV entry table>>
[*08/17/2021 17:21:16.9381] Discovery Response from 10.144.88.24
[*08/17/2021 17:21:16.9381] << TLV table entries: 2 for TLV_EXPIRE_MIC_TYPE_PAYLOAD>>
[*08/17/2021 17:21:16.9382] Entry( 0): level 0 type 661 size 0 value Nested
[*08/17/2021 17:21:16.9382] Entry( 1): level 1 type 1 size 1 value 0
Thanks for the help.
Guillermo
Rich R
The AP log you attached is not the full log - we need to see the full log from power on.
Have you tried a factory reset on that AP?
6 Replies 6
marce1000
           - Check if you have sufficient (ap-) licenses with show license summary , also check if the regulatory domain of the ap and controller match.
 M.
Thank for you comments. How I can check the regulatory domain in the AP?
Guillermo
Arshad Safrulla
Did you convert this AP to Mobility express as well? You should not have two controllers.  You will have to choose one ME WLC and another as Save AP, this slave AP should be lightweight.
To remove ME on Slave AP you can try the below command
config ap unifiedmode {WLC Name} {AP Manager IP}
Hello. Thank for you help, I know that it´s possible that I can to have two Mobility Controller, now the problem is that the access point can not to join the controller, I accept another suggest.
Guillermo
Rich R
Hello, I factory reset at the AP, the problem resolve.
regards
Guillermo
