AP 350 Management via CiscoWorks2000
lferreruela
Has anybody managed the Aironet 350 APs using CiscoWorks 2000? If so, what can you tell me. I have doubts about if you can do more things using CW2000 than if you are using HP OV. Of course if you want to manage CISCO switches the CW2000 gives you much more possibilities than HP OV, but with access points... I fear that you can do little more than see the map (CDP) and change configuration parameters using SNMP, MIB I and MIB II as you would do with HP OV.
I believe the Aironet 350 do not support RMON. What profit can you get from NGENIUS, CISCO VIEW?
Does the Device Fault Manager detect faults on Aironet access points?
rmushtaq
Level 8
Level 8
Currently, only Cisco View supports AP340/350. Other components of CW2000 does not support these at the moment.
sergio.lewis
Has anybody managed the Aironet 350 APs using Cisco Works 2000? If so, what can you tell me.
Aw…Yeap! At this moment you have 5 categories, port monitor and don’t forget the command line with telnet or browser.
Aw… Don’t forget that CW2K is for manage the Cisco’s equipments but you can get the benefices of HP OV for example history of the each node.
Aw… with Cisco View y can manage the Cisco’s equipments graphically but don’t forget the command line because some command only exist in the command line area.
Aw… Yes,
Path Analysis provides various commands and several approaches you can use to enable information navigation.
CiscoWorks2000 Device Fault Manager product:
· DFM
· DFM Architecture
· Elements Monitored by DFM
· DFM Collects Inventory Information
· DFM Monitors Networks
· DFM Reports
· Supported Devices
CiscoView is a graphical SNMP-based device management tool that provides real-time views of networked Cisco Systems devices. These views deliver a continuously updated physical picture of device configuration and performance conditions, with simultaneous views available for multiple device sessions.
CiscoView operates in two versions: CiscoWorks2000 or CiscoWorks for Windows. Both versions are browser-based applications.
In CiscoWorks2000 version, the device package and basic management functionality is centrally located on the CiscoView server, and management functionalities can be accessed from remote browsers.
In CiscoWorks for Windows version, the device package, basic management functionality, and user interface are installed and operated on the same machine.
From the CiscoView interface you can:
· View a graphical representation of the device, including component (interface, card, power supply) status.
· Configure parameters for devices, cards, and interfaces.
· Monitor real-time statistics for interfaces, resource utilization, and device performance.
· Telnet, access CCO, send email to TAC, set values for SNMP parameters and community strings.
· Perform device-specific operations as defined in each device package.
· Manage groups of stackable devices.
CiscoView contains common devices functions such as selecting main menu options and categories of information for configuring and monitoring. Each device package also has its own specific menu options and functions.
The Resource Manager Essentials (Essentials) suite is part of the CiscoWorks2000 family of products. It is an enterprise solution to network management. This suite of web-based network management tools enables administrators to collect the monitoring, fault, and availability information needed to track devices critical to the network. Essentials is based on a client/server architecture that connects multiple web-based clients to a server on the network. As the number of network devices increases, additional servers or collection points can be added to manage network growth with little impact on the client browser application.
By taking advantage of the scalability inherent in the intranet architecture, Essentials supports multiple users anywhere on the network. The web-based infrastructure gives network operators, administrators, technicians, Help Desk staff, IS managers, and end users access to network management tools, applications, and services.
Essentials applications provide the network monitoring and fault information you need to track devices critical to network uptime and application availability. They also provide tools that you can use to rapidly and reliably deploy Cisco software images and view configurations of Cisco routers and switches. Essentials applications, together with links to cisco.com service and support, automate software maintenance to help you maintain and control your enterprise network.
RMON-MIB is not supported by Aironet 350!
Ngenius…. Is like a IDS but it’s for monitor segment of networks in real-time you have to buy this black box and plug into your network and then real time monitor.
Aw…yes it have one category called Event Display Setup
Event Display Setup
The dialog box allows you to determine how time should be displayed on the Event Log. In addition, you can determine what severity level is significant enough to display an event.
Procedure
1. Right-click on the device and select Device Menu > Events from the popup menu. The Events dialog box appears.
2. Select Event Display Setup from the Category drop-down list box.
The following information appears:
Offset from GMT (awcEventOffsetGMT)
The current offset, in minutes, from GMT.
Use Daylight Savings Time (awcEventUseDaylightSavingsTime)
Set this value to true to use daylight savings time.
GMT Time (awcEventTimestampGMT)
The GMT time, in seconds, since January 1, 1970, when the system wall-clock time was last set.
System uptime (awcEventUptimeModifiedGMT)
The system uptime, in seconds, when the system wall-clock time was last set.
Display Wall-Clock Time? (awcEventDisplayWallClockTime)
Set the value to true to display the wall-clock time. False means, the display is in system uptime.
Display Uptime Ascending? (awcEventDisplayUptimeAscending)
Set the value to true to display time in system uptime measured from the time the system boots forward. False means, time display is measured from the current time backwards.
Event Detail Level (awcEventDetailDefault)
The default event details level.
Severity Level for Console Display (awcEventSeverityDispConsole)
The event severity level to be displayed on the console.
Severity Level for GUI Display (awcEventSeverityDispHtmlGUI)
The event severity level to be displayed on the GUI.
Severity Level for Console Browser Disp (awcEventSeverityDispHtmlConsole)
The event severity level to be displayed on the console browser.
Alert SNMP (awcEventAlertSNMP)
Set this value to true to generate SNMP trap for events of severity with disposition set to Notify.
Alert Syslog (awcEventAlertSyslog)
Set this value to true to generate sysLog message for events of severity with disposition set to Notify.
Syslog Destination (awcEventSyslogAddr)
The destination of a syslog message.
Facility Number (awcEventSyslogFacility)
The facility number encoded within a sysLog message.
Trace Station Severity (awcEventTraceStationSeverity)
The severity at which all detailed packet trace events are handled.
Trace Log Size (Octets) (awcEventTraceLogSize)
The size, in octets, of the detailed system event trace buffer.
Max Size of Event in Trace Log (awcEventTracePacketLen)
The maximum size, in octets, of each packet trace event recorded in the detailed event trace buffer.
By the way the AP350 have 2920 records exported to MIB.
Hope all this help!
Sergio Lewis
MIB OID Name Value
RFC1213-MIB 1.3.6.1.2.1.1.1.0 sysDescr.0 Cisco 350 Series AP 11.06
RFC1213-MIB 1.3.6.1.2.1.1.2.0 sysObjectID.0 1.3.6.1.4.1.9.1.380
RFC1213-MIB 1.3.6.1.2.1.1.3.0 sysUpTime.0 186089000
RFC1213-MIB 1.3.6.1.2.1.1.4.0 sysContact.0 Aironet Wireless Communications, Inc.
RFC1213-MIB 1.3.6.1.2.1.1.5.0 sysName.0 CRO001AP01
RFC1213-MIB 1.3.6.1.2.1.1.6.0 sysLocation.0 CSU
RFC1213-MIB 1.3.6.1.2.1.1.7.0 sysServices.0 79
RFC1213-MIB 1.3.6.1.2.1.2.1.0 ifNumber.0 36
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.1 ifIndex.1 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.2 ifIndex.2 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.3 ifIndex.3 3
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.9 ifIndex.9 9
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.10 ifIndex.10 10
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.11 ifIndex.11 11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.12 ifIndex.12 12
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.13 ifIndex.13 13
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.14 ifIndex.14 14
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.15 ifIndex.15 15
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.16 ifIndex.16 16
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.17 ifIndex.17 17
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.18 ifIndex.18 18
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.19 ifIndex.19 19
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.20 ifIndex.20 20
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.21 ifIndex.21 21
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.22 ifIndex.22 22
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.23 ifIndex.23 23
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.24 ifIndex.24 24
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.25 ifIndex.25 25
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.26 ifIndex.26 26
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.27 ifIndex.27 27
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.28 ifIndex.28 28
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.29 ifIndex.29 29
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.30 ifIndex.30 30
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.31 ifIndex.31 31
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.32 ifIndex.32 32
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.33 ifIndex.33 33
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.34 ifIndex.34 34
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.35 ifIndex.35 35
RFC1213-MIB 1.3.6.1.2.1.2.2.1.1.36 ifIndex.36 36
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.1 ifDescr.1 fec0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.2 ifDescr.2 awc0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.3 ifDescr.3 lo0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.9 ifDescr.9 rptr1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.10 ifDescr.10 rptr2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.11 ifDescr.11 rptr3
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.12 ifDescr.12 rptr4
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.13 ifDescr.13 rptr5
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.14 ifDescr.14 rptr6
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.15 ifDescr.15 rptr7
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.16 ifDescr.16 rptr8
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.17 ifDescr.17 rptr9
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.18 ifDescr.18 rptr10
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.19 ifDescr.19 rptr11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.20 ifDescr.20 rptr12
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.21 ifDescr.21 rptr13
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.22 ifDescr.22 rptr14
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.23 ifDescr.23 rptr15
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.24 ifDescr.24 rptr16
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.25 ifDescr.25 rptr17
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.26 ifDescr.26 rptr18
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.27 ifDescr.27 rptr19
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.28 ifDescr.28 rptr20
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.29 ifDescr.29 rptr21
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.30 ifDescr.30 rptr22
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.31 ifDescr.31 rptr23
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.32 ifDescr.32 rptr24
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.33 ifDescr.33 rptr25
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.34 ifDescr.34 rptr26
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.35 ifDescr.35 rptr27
RFC1213-MIB 1.3.6.1.2.1.2.2.1.2.36 ifDescr.36 rptr28
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.1 ifType.1 6
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.2 ifType.2 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.3 ifType.3 24
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.9 ifType.9 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.10 ifType.10 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.11 ifType.11 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.12 ifType.12 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.13 ifType.13 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.14 ifType.14 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.15 ifType.15 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.16 ifType.16 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.17 ifType.17 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.18 ifType.18 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.19 ifType.19 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.20 ifType.20 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.21 ifType.21 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.22 ifType.22 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.23 ifType.23 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.24 ifType.24 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.25 ifType.25 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.26 ifType.26 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.27 ifType.27 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.28 ifType.28 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.29 ifType.29 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.30 ifType.30 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.31 ifType.31 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.32 ifType.32 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.33 ifType.33 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.34 ifType.34 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.35 ifType.35 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.3.36 ifType.36 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.1 ifMtu.1 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.2 ifMtu.2 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.3 ifMtu.3 32768
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.9 ifMtu.9 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.10 ifMtu.10 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.11 ifMtu.11 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.12 ifMtu.12 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.13 ifMtu.13 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.14 ifMtu.14 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.15 ifMtu.15 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.16 ifMtu.16 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.17 ifMtu.17 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.18 ifMtu.18 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.19 ifMtu.19 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.20 ifMtu.20 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.21 ifMtu.21 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.22 ifMtu.22 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.23 ifMtu.23 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.24 ifMtu.24 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.25 ifMtu.25 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.26 ifMtu.26 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.27 ifMtu.27 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.28 ifMtu.28 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.29 ifMtu.29 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.30 ifMtu.30 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.31 ifMtu.31 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.32 ifMtu.32 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.33 ifMtu.33 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.34 ifMtu.34 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.35 ifMtu.35 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.4.36 ifMtu.36 1500
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.1 ifSpeed.1 100000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.2 ifSpeed.2 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.3 ifSpeed.3 100000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.9 ifSpeed.9 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.10 ifSpeed.10 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.11 ifSpeed.11 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.12 ifSpeed.12 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.13 ifSpeed.13 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.14 ifSpeed.14 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.15 ifSpeed.15 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.16 ifSpeed.16 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.17 ifSpeed.17 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.18 ifSpeed.18 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.19 ifSpeed.19 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.20 ifSpeed.20 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.21 ifSpeed.21 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.22 ifSpeed.22 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.23 ifSpeed.23 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.24 ifSpeed.24 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.25 ifSpeed.25 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.26 ifSpeed.26 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.27 ifSpeed.27 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.28 ifSpeed.28 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.29 ifSpeed.29 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.30 ifSpeed.30 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.31 ifSpeed.31 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.32 ifSpeed.32 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.33 ifSpeed.33 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.34 ifSpeed.34 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.35 ifSpeed.35 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.5.36 ifSpeed.36 11000000
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.1 ifPhysAddress.1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.2 ifPhysAddress.2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.3 ifPhysAddress.3
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.9 ifPhysAddress.9
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.10 ifPhysAddress.10
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.11 ifPhysAddress.11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.12 ifPhysAddress.12
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.13 ifPhysAddress.13
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.14 ifPhysAddress.14
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.15 ifPhysAddress.15
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.16 ifPhysAddress.16
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.17 ifPhysAddress.17
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.18 ifPhysAddress.18
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.19 ifPhysAddress.19
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.20 ifPhysAddress.20
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.21 ifPhysAddress.21
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.22 ifPhysAddress.22
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.23 ifPhysAddress.23
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.24 ifPhysAddress.24
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.25 ifPhysAddress.25
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.26 ifPhysAddress.26
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.27 ifPhysAddress.27
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.28 ifPhysAddress.28
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.29 ifPhysAddress.29
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.30 ifPhysAddress.30
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.31 ifPhysAddress.31
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.32 ifPhysAddress.32
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.33 ifPhysAddress.33
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.34 ifPhysAddress.34
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.35 ifPhysAddress.35
RFC1213-MIB 1.3.6.1.2.1.2.2.1.6.36 ifPhysAddress.36
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.1 ifAdminStatus.1 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.2 ifAdminStatus.2 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.3 ifAdminStatus.3 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.9 ifAdminStatus.9 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.10 ifAdminStatus.10 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.11 ifAdminStatus.11 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.12 ifAdminStatus.12 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.13 ifAdminStatus.13 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.14 ifAdminStatus.14 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.15 ifAdminStatus.15 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.16 ifAdminStatus.16 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.17 ifAdminStatus.17 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.18 ifAdminStatus.18 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.19 ifAdminStatus.19 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.20 ifAdminStatus.20 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.21 ifAdminStatus.21 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.22 ifAdminStatus.22 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.23 ifAdminStatus.23 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.24 ifAdminStatus.24 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.25 ifAdminStatus.25 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.26 ifAdminStatus.26 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.27 ifAdminStatus.27 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.28 ifAdminStatus.28 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.29 ifAdminStatus.29 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.30 ifAdminStatus.30 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.31 ifAdminStatus.31 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.32 ifAdminStatus.32 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.33 ifAdminStatus.33 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.34 ifAdminStatus.34 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.35 ifAdminStatus.35 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.7.36 ifAdminStatus.36 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.1 ifOperStatus.1 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.2 ifOperStatus.2 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.3 ifOperStatus.3 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.9 ifOperStatus.9 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.10 ifOperStatus.10 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.11 ifOperStatus.11 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.12 ifOperStatus.12 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.13 ifOperStatus.13 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.14 ifOperStatus.14 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.15 ifOperStatus.15 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.16 ifOperStatus.16 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.17 ifOperStatus.17 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.18 ifOperStatus.18 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.19 ifOperStatus.19 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.20 ifOperStatus.20 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.21 ifOperStatus.21 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.22 ifOperStatus.22 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.23 ifOperStatus.23 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.24 ifOperStatus.24 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.25 ifOperStatus.25 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.26 ifOperStatus.26 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.27 ifOperStatus.27 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.28 ifOperStatus.28 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.29 ifOperStatus.29 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.30 ifOperStatus.30 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.31 ifOperStatus.31 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.32 ifOperStatus.32 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.33 ifOperStatus.33 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.34 ifOperStatus.34 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.35 ifOperStatus.35 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.8.36 ifOperStatus.36 2
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.1 ifLastChange.1 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.2 ifLastChange.2 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.3 ifLastChange.3 1930
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.9 ifLastChange.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.10 ifLastChange.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.11 ifLastChange.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.12 ifLastChange.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.13 ifLastChange.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.14 ifLastChange.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.15 ifLastChange.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.16 ifLastChange.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.17 ifLastChange.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.18 ifLastChange.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.19 ifLastChange.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.20 ifLastChange.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.21 ifLastChange.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.22 ifLastChange.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.23 ifLastChange.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.24 ifLastChange.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.25 ifLastChange.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.26 ifLastChange.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.27 ifLastChange.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.28 ifLastChange.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.29 ifLastChange.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.30 ifLastChange.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.31 ifLastChange.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.32 ifLastChange.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.33 ifLastChange.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.34 ifLastChange.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.35 ifLastChange.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.9.36 ifLastChange.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.1 ifInOctets.1 305349629
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.2 ifInOctets.2 316220266
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.3 ifInOctets.3 1048
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.9 ifInOctets.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.10 ifInOctets.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.11 ifInOctets.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.12 ifInOctets.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.13 ifInOctets.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.14 ifInOctets.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.15 ifInOctets.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.16 ifInOctets.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.17 ifInOctets.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.18 ifInOctets.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.19 ifInOctets.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.20 ifInOctets.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.21 ifInOctets.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.22 ifInOctets.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.23 ifInOctets.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.24 ifInOctets.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.25 ifInOctets.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.26 ifInOctets.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.27 ifInOctets.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.28 ifInOctets.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.29 ifInOctets.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.30 ifInOctets.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.31 ifInOctets.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.32 ifInOctets.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.33 ifInOctets.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.34 ifInOctets.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.35 ifInOctets.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.10.36 ifInOctets.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.1 ifInUcastPkts.1 17576662
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.2 ifInUcastPkts.2 1366024
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.3 ifInUcastPkts.3 11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.9 ifInUcastPkts.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.10 ifInUcastPkts.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.11 ifInUcastPkts.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.12 ifInUcastPkts.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.13 ifInUcastPkts.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.14 ifInUcastPkts.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.15 ifInUcastPkts.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.16 ifInUcastPkts.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.17 ifInUcastPkts.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.18 ifInUcastPkts.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.19 ifInUcastPkts.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.20 ifInUcastPkts.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.21 ifInUcastPkts.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.22 ifInUcastPkts.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.23 ifInUcastPkts.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.24 ifInUcastPkts.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.25 ifInUcastPkts.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.26 ifInUcastPkts.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.27 ifInUcastPkts.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.28 ifInUcastPkts.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.29 ifInUcastPkts.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.30 ifInUcastPkts.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.31 ifInUcastPkts.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.32 ifInUcastPkts.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.33 ifInUcastPkts.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.34 ifInUcastPkts.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.35 ifInUcastPkts.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.11.36 ifInUcastPkts.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.1 ifInNUcastPkts.1 4427117
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.2 ifInNUcastPkts.2 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.3 ifInNUcastPkts.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.9 ifInNUcastPkts.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.10 ifInNUcastPkts.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.11 ifInNUcastPkts.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.12 ifInNUcastPkts.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.13 ifInNUcastPkts.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.14 ifInNUcastPkts.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.15 ifInNUcastPkts.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.16 ifInNUcastPkts.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.17 ifInNUcastPkts.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.18 ifInNUcastPkts.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.19 ifInNUcastPkts.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.20 ifInNUcastPkts.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.21 ifInNUcastPkts.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.22 ifInNUcastPkts.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.23 ifInNUcastPkts.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.24 ifInNUcastPkts.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.25 ifInNUcastPkts.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.26 ifInNUcastPkts.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.27 ifInNUcastPkts.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.28 ifInNUcastPkts.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.29 ifInNUcastPkts.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.30 ifInNUcastPkts.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.31 ifInNUcastPkts.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.32 ifInNUcastPkts.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.33 ifInNUcastPkts.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.34 ifInNUcastPkts.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.35 ifInNUcastPkts.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.12.36 ifInNUcastPkts.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.1 ifInDiscards.1 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.2 ifInDiscards.2 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.3 ifInDiscards.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.9 ifInDiscards.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.10 ifInDiscards.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.11 ifInDiscards.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.12 ifInDiscards.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.13 ifInDiscards.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.14 ifInDiscards.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.15 ifInDiscards.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.16 ifInDiscards.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.17 ifInDiscards.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.18 ifInDiscards.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.19 ifInDiscards.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.20 ifInDiscards.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.21 ifInDiscards.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.22 ifInDiscards.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.23 ifInDiscards.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.24 ifInDiscards.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.25 ifInDiscards.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.26 ifInDiscards.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.27 ifInDiscards.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.28 ifInDiscards.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.29 ifInDiscards.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.30 ifInDiscards.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.31 ifInDiscards.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.32 ifInDiscards.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.33 ifInDiscards.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.34 ifInDiscards.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.35 ifInDiscards.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.13.36 ifInDiscards.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.1 ifInErrors.1 453
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.2 ifInErrors.2 1333
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.3 ifInErrors.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.9 ifInErrors.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.10 ifInErrors.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.11 ifInErrors.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.12 ifInErrors.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.13 ifInErrors.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.14 ifInErrors.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.15 ifInErrors.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.16 ifInErrors.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.17 ifInErrors.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.18 ifInErrors.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.19 ifInErrors.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.20 ifInErrors.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.21 ifInErrors.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.22 ifInErrors.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.23 ifInErrors.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.24 ifInErrors.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.25 ifInErrors.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.26 ifInErrors.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.27 ifInErrors.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.28 ifInErrors.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.29 ifInErrors.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.30 ifInErrors.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.31 ifInErrors.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.32 ifInErrors.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.33 ifInErrors.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.34 ifInErrors.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.35 ifInErrors.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.14.36 ifInErrors.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.1 ifInUnknownProtos.1 11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.2 ifInUnknownProtos.2 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.3 ifInUnknownProtos.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.9 ifInUnknownProtos.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.10 ifInUnknownProtos.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.11 ifInUnknownProtos.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.12 ifInUnknownProtos.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.13 ifInUnknownProtos.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.14 ifInUnknownProtos.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.15 ifInUnknownProtos.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.16 ifInUnknownProtos.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.17 ifInUnknownProtos.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.18 ifInUnknownProtos.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.19 ifInUnknownProtos.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.20 ifInUnknownProtos.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.21 ifInUnknownProtos.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.22 ifInUnknownProtos.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.23 ifInUnknownProtos.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.24 ifInUnknownProtos.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.25 ifInUnknownProtos.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.26 ifInUnknownProtos.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.27 ifInUnknownProtos.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.28 ifInUnknownProtos.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.29 ifInUnknownProtos.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.30 ifInUnknownProtos.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.31 ifInUnknownProtos.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.32 ifInUnknownProtos.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.33 ifInUnknownProtos.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.34 ifInUnknownProtos.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.35 ifInUnknownProtos.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.15.36 ifInUnknownProtos.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.1 ifOutOctets.1 3250396528
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.2 ifOutOctets.2 512101818
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.3 ifOutOctets.3 1048
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.9 ifOutOctets.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.10 ifOutOctets.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.11 ifOutOctets.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.12 ifOutOctets.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.13 ifOutOctets.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.14 ifOutOctets.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.15 ifOutOctets.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.16 ifOutOctets.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.17 ifOutOctets.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.18 ifOutOctets.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.19 ifOutOctets.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.20 ifOutOctets.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.21 ifOutOctets.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.22 ifOutOctets.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.23 ifOutOctets.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.24 ifOutOctets.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.25 ifOutOctets.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.26 ifOutOctets.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.27 ifOutOctets.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.28 ifOutOctets.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.29 ifOutOctets.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.30 ifOutOctets.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.31 ifOutOctets.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.32 ifOutOctets.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.33 ifOutOctets.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.34 ifOutOctets.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.35 ifOutOctets.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.16.36 ifOutOctets.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.1 ifOutUcastPkts.1 15444498
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.2 ifOutUcastPkts.2 980589
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.3 ifOutUcastPkts.3 11
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.9 ifOutUcastPkts.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.10 ifOutUcastPkts.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.11 ifOutUcastPkts.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.12 ifOutUcastPkts.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.13 ifOutUcastPkts.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.14 ifOutUcastPkts.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.15 ifOutUcastPkts.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.16 ifOutUcastPkts.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.17 ifOutUcastPkts.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.18 ifOutUcastPkts.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.19 ifOutUcastPkts.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.20 ifOutUcastPkts.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.21 ifOutUcastPkts.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.22 ifOutUcastPkts.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.23 ifOutUcastPkts.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.24 ifOutUcastPkts.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.25 ifOutUcastPkts.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.26 ifOutUcastPkts.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.27 ifOutUcastPkts.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.28 ifOutUcastPkts.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.29 ifOutUcastPkts.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.30 ifOutUcastPkts.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.31 ifOutUcastPkts.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.32 ifOutUcastPkts.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.33 ifOutUcastPkts.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.34 ifOutUcastPkts.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.35 ifOutUcastPkts.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.17.36 ifOutUcastPkts.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.1 ifOutNUcastPkts.1 120702
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.2 ifOutNUcastPkts.2 266659
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.3 ifOutNUcastPkts.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.9 ifOutNUcastPkts.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.10 ifOutNUcastPkts.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.11 ifOutNUcastPkts.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.12 ifOutNUcastPkts.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.13 ifOutNUcastPkts.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.14 ifOutNUcastPkts.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.15 ifOutNUcastPkts.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.16 ifOutNUcastPkts.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.17 ifOutNUcastPkts.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.18 ifOutNUcastPkts.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.19 ifOutNUcastPkts.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.20 ifOutNUcastPkts.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.21 ifOutNUcastPkts.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.22 ifOutNUcastPkts.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.23 ifOutNUcastPkts.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.24 ifOutNUcastPkts.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.25 ifOutNUcastPkts.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.26 ifOutNUcastPkts.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.27 ifOutNUcastPkts.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.28 ifOutNUcastPkts.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.29 ifOutNUcastPkts.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.30 ifOutNUcastPkts.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.31 ifOutNUcastPkts.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.32 ifOutNUcastPkts.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.33 ifOutNUcastPkts.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.34 ifOutNUcastPkts.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.35 ifOutNUcastPkts.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.18.36 ifOutNUcastPkts.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.1 ifOutDiscards.1 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.2 ifOutDiscards.2 1
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.3 ifOutDiscards.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.9 ifOutDiscards.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.10 ifOutDiscards.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.11 ifOutDiscards.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.12 ifOutDiscards.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.13 ifOutDiscards.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.14 ifOutDiscards.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.15 ifOutDiscards.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.16 ifOutDiscards.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.17 ifOutDiscards.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.18 ifOutDiscards.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.19 ifOutDiscards.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.20 ifOutDiscards.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.21 ifOutDiscards.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.22 ifOutDiscards.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.23 ifOutDiscards.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.24 ifOutDiscards.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.25 ifOutDiscards.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.26 ifOutDiscards.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.27 ifOutDiscards.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.28 ifOutDiscards.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.29 ifOutDiscards.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.30 ifOutDiscards.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.31 ifOutDiscards.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.32 ifOutDiscards.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.33 ifOutDiscards.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.34 ifOutDiscards.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.35 ifOutDiscards.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.19.36 ifOutDiscards.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.1 ifOutErrors.1 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.2 ifOutErrors.2 359
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.3 ifOutErrors.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.9 ifOutErrors.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.10 ifOutErrors.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.11 ifOutErrors.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.12 ifOutErrors.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.13 ifOutErrors.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.14 ifOutErrors.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.15 ifOutErrors.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.16 ifOutErrors.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.17 ifOutErrors.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.18 ifOutErrors.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.19 ifOutErrors.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.20 ifOutErrors.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.21 ifOutErrors.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.22 ifOutErrors.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.23 ifOutErrors.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.24 ifOutErrors.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.25 ifOutErrors.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.26 ifOutErrors.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.27 ifOutErrors.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.28 ifOutErrors.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.29 ifOutErrors.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.30 ifOutErrors.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.31 ifOutErrors.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.32 ifOutErrors.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.33 ifOutErrors.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.34 ifOutErrors.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.35 ifOutErrors.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.20.36 ifOutErrors.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.1 ifOutQLen.1 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.2 ifOutQLen.2 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.3 ifOutQLen.3 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.9 ifOutQLen.9 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.10 ifOutQLen.10 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.11 ifOutQLen.11 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.12 ifOutQLen.12 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.13 ifOutQLen.13 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.14 ifOutQLen.14 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.15 ifOutQLen.15 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.16 ifOutQLen.16 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.17 ifOutQLen.17 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.18 ifOutQLen.18 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.19 ifOutQLen.19 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.20 ifOutQLen.20 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.21 ifOutQLen.21 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.22 ifOutQLen.22 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.23 ifOutQLen.23 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.24 ifOutQLen.24 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.25 ifOutQLen.25 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.26 ifOutQLen.26 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.27 ifOutQLen.27 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.28 ifOutQLen.28 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.29 ifOutQLen.29 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.30 ifOutQLen.30 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.31 ifOutQLen.31 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.32 ifOutQLen.32 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.33 ifOutQLen.33 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.34 ifOutQLen.34 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.35 ifOutQLen.35 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.21.36 ifOutQLen.36 0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.1 ifSpecific.1 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.2 ifSpecific.2 1.2.840.10036
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.3 ifSpecific.3 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.9 ifSpecific.9 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.10 ifSpecific.10 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.11 ifSpecific.11 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.12 ifSpecific.12 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.13 ifSpecific.13 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.14 ifSpecific.14 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.15 ifSpecific.15 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.16 ifSpecific.16 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.17 ifSpecific.17 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.18 ifSpecific.18 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.19 ifSpecific.19 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.20 ifSpecific.20 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.21 ifSpecific.21 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.22 ifSpecific.22 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.23 ifSpecific.23 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.24 ifSpecific.24 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.25 ifSpecific.25 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.26 ifSpecific.26 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.27 ifSpecific.27 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.28 ifSpecific.28 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.29 ifSpecific.29 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.30 ifSpecific.30 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.31 ifSpecific.31 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.32 ifSpecific.32 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.33 ifSpecific.33 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.34 ifSpecific.34 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.35 ifSpecific.35 0.0
RFC1213-MIB 1.3.6.1.2.1.2.2.1.22.36 ifSpecific.36 0.0
RFC1213-MIB 1.3.6.1.2.1.4.1.0 ipForwarding.0 2
RFC1213-MIB 1.3.6.1.2.1.4.2.0 ipDefaultTTL.0 64
RFC1213-MIB 1.3.6.1.2.1.4.3.0 ipInReceives.0 1031471
RFC1213-MIB 1.3.6.1.2.1.4.4.0 ipInHdrErrors.0 0
RFC1213-MIB 1.3.6.1.2.1.4.5.0 ipInAddrErrors.0 1500
RFC1213-MIB 1.3.6.1.2.1.4.6.0 ipForwDatagrams.0 0
RFC1213-MIB 1.3.6.1.2.1.4.7.0 ipInUnknownProtos.0 8
RFC1213-MIB 1.3.6.1.2.1.4.8.0 ipInDiscards.0 0
RFC1213-MIB 1.3.6.1.2.1.4.9.0 ipInDelivers.0 1029972
RFC1213-MIB 1.3.6.1.2.1.4.10.0 ipOutRequests.0 119955
RFC1213-MIB 1.3.6.1.2.1.4.11.0 ipOutDiscards.0 0
RFC1213-MIB 1.3.6.1.2.1.4.12.0 ipOutNoRoutes.0 0
RFC1213-MIB 1.3.6.1.2.1.4.13.0 ipReasmTimeout.0 60
RFC1213-MIB 1.3.6.1.2.1.4.14.0 ipReasmReqds.0 0
RFC1213-MIB 1.3.6.1.2.1.4.15.0 ipReasmOKs.0 0
RFC1213-MIB 1.3.6.1.2.1.4.16.0 ipReasmFails.0 0
RFC1213-MIB 1.3.6.1.2.1.4.17.0 ipFragOKs.0 0
RFC1213-MIB 1.3.6.1.2.1.4.18.0 ipFragFails.0 0
RFC1213-MIB 1.3.6.1.2.1.4.19.0 ipFragCreates.0 0
RFC1213-MIB 1.3.6.1.2.1.4.20.1.1.172.20.11.240 ipAdEntAddr.172.20.11.240 172.20.11.240
RFC1213-MIB 1.3.6.1.2.1.4.20.1.2.172.20.11.240 ipAdEntIfIndex.172.20.11.240 2
RFC1213-MIB 1.3.6.1.2.1.4.20.1.3.172.20.11.240 ipAdEntNetMask.172.20.11.240 255.255.255.0
RFC1213-MIB 1.3.6.1.2.1.4.20.1.4.172.20.11.240 ipAdEntBcastAddr.172.20.11.240 1
RFC1213-MIB 1.3.6.1.2.1.4.20.1.5.172.20.11.240 ipAdEntReasmMaxSize.172.20.11.240 65535
RFC1213-MIB 1.3.6.1.2.1.4.21.1.1.0.0.0.0 ipRouteDest.0.0.0.0 0.0.0.0
RFC1213-MIB 1.3.6.1.2.1.4.21.1.2.0.0.0.0 ipRouteIfIndex.0.0.0.0 1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.3.0.0.0.0 ipRouteMetric1.0.0.0.0 -1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.4.0.0.0.0 ipRouteMetric2.0.0.0.0 -1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.5.0.0.0.0 ipRouteMetric3.0.0.0.0 -1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.6.0.0.0.0 ipRouteMetric4.0.0.0.0 -1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.7.0.0.0.0 ipRouteNextHop.0.0.0.0 172.20.11.252
RFC1213-MIB 1.3.6.1.2.1.4.21.1.8.0.0.0.0 ipRouteType.0.0.0.0 1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.9.0.0.0.0 ipRouteProto.0.0.0.0 1
RFC1213-MIB 1.3.6.1.2.1.4.21.1.10.0.0.0.0 ipRouteAge.0.0.0.0 0
RFC1213-MIB 1.3.6.1.2.1.4.21.1.11.0.0.0.0 ipRouteMask.0.0.0.0 0.0.0.0
RFC1213-MIB 1.3.6.1.2.1.4.21.1.12.0.0.0.0 ipRouteMetric5.0.0.0.0 -1
RFC1213-MIB 1.3.6.1.2.1.4.23.0 ipRoutingDiscards.0 0
RFC1213-MIB 1.3.6.1.2.1.6.1.0 tcpRtoAlgorithm.0 4
RFC1213-MIB 1.3.6.1.2.1.6.2.0 tcpRtoMin.0 1000
RFC1213-MIB 1.3.6.1.2.1.6.3.0 tcpRtoMax.0 64000
RFC1213-MIB 1.3.6.1.2.1.6.4.0 tcpMaxConn.0 -1
RFC1213-MIB 1.3.6.1.2.1.6.5.0 tcpActiveOpens.0 1
RFC1213-MIB 1.3.6.1.2.1.6.6.0 tcpPassiveOpens.0 387
RFC1213-MIB 1.3.6.1.2.1.6.7.0 tcpAttemptFails.0 0
RFC1213-MIB 1.3.6.1.2.1.6.8.0 tcpEstabResets.0 350
RFC1213-MIB 1.3.6.1.2.1.6.9.0 tcpCurrEstab.0 0
RFC1213-MIB 1.3.6.1.2.1.6.10.0 tcpInSegs.0 4308
RFC1213-MIB 1.3.6.1.2.1.6.11.0 tcpOutSegs.0 3631
RFC1213-MIB 1.3.6.1.2.1.6.12.0 tcpRetransSegs.0 11
RFC1213-MIB 1.3.6.1.2.1.6.14.0 tcpInErrs.0 0
RFC1213-MIB 1.3.6.1.2.1.6.15.0 tcpOutRsts.0 1402
RFC1213-MIB 1.3.6.1.2.1.7.1.0 udpInDatagrams.0 102450
RFC1213-MIB 1.3.6.1.2.1.7.2.0 udpNoPorts.0 911369
RFC1213-MIB 1.3.6.1.2.1.7.3.0 udpInErrors.0 0
RFC1213-MIB 1.3.6.1.2.1.7.4.0 udpOutDatagrams.0 101619
RFC1213-MIB 1.3.6.1.2.1.11.1.0 snmpInPkts.0 109867
RFC1213-MIB 1.3.6.1.2.1.11.2.0 snmpOutPkts.0 101613
RFC1213-MIB 1.3.6.1.2.1.11.3.0 snmpInBadVersions.0 0
RFC1213-MIB 1.3.6.1.2.1.11.4.0 snmpInBadCommunityNames.0 628
RFC1213-MIB 1.3.6.1.2.1.11.5.0 snmpInBadCommunityUses.0 0
RFC1213-MIB 1.3.6.1.2.1.11.6.0 snmpInASNParseErrs.0 8134
RFC1213-MIB 1.3.6.1.2.1.11.8.0 snmpInTooBigs.0 0
RFC1213-MIB 1.3.6.1.2.1.11.9.0 snmpInNoSuchNames.0 0
RFC1213-MIB 1.3.6.1.2.1.11.10.0 snmpInBadValues.0 0
RFC1213-MIB 1.3.6.1.2.1.11.11.0 snmpInReadOnlys.0 0
RFC1213-MIB 1.3.6.1.2.1.11.12.0 snmpInGenErrs.0 0
RFC1213-MIB 1.3.6.1.2.1.11.13.0 snmpInTotalReqVars.0 243969
RFC1213-MIB 1.3.6.1.2.1.11.14.0 snmpInTotalSetVars.0 7
RFC1213-MIB 1.3.6.1.2.1.11.15.0 snmpInGetRequests.0 33866
RFC1213-MIB 1.3.6.1.2.1.11.16.0 snmpInGetNexts.0 67248
RFC1213-MIB 1.3.6.1.2.1.11.17.0 snmpInSetRequests.0 4
RFC1213-MIB 1.3.6.1.2.1.11.18.0 snmpInGetResponses.0 0
RFC1213-MIB 1.3.6.1.2.1.11.19.0 snmpInTraps.0 0
RFC1213-MIB 1.3.6.1.2.1.11.20.0 snmpOutTooBigs.0 0
RFC1213-MIB 1.3.6.1.2.1.11.21.0 snmpOutNoSuchNames.0 34
RFC1213-MIB 1.3.6.1.2.1.11.22.0 snmpOutBadValues.0 0
RFC1213-MIB 1.3.6.1.2.1.11.24.0 snmpOutGenErrs.0 8
RFC1213-MIB 1.3.6.1.2.1.11.25.0 snmpOutGetRequests.0 0
RFC1213-MIB 1.3.6.1.2.1.11.26.0 snmpOutGetNexts.0 0
RFC1213-MIB 1.3.6.1.2.1.11.27.0 snmpOutSetRequests.0 0
RFC1213-MIB 1.3.6.1.2.1.11.28.0 snmpOutGetResponses.0 101129
RFC1213-MIB 1.3.6.1.2.1.11.29.0 snmpOutTraps.0 508
BLC 1.3.6.1.2.1.11.30.0 snmpEnableAuthTraps.0 0
SNMPv2-MIB 1.3.6.1.2.1.11.31.0 snmpSilentDrops.0 0
SNMPv2-MIB 1.3.6.1.2.1.11.32.0 snmpProxyDrops.0 0
RFC1155-SMI 1.3.6.1.2.1.17.1.1.0 mgmt.1.17.1.1.0
RFC1155-SMI 1.3.6.1.2.1.17.1.2.0 mgmt.1.17.1.2.0 32
RFC1155-SMI 1.3.6.1.2.1.17.1.3.0 mgmt.1.17.1.3.0 2
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.1 mgmt.1.17.1.4.1.1.1 1
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.2 mgmt.1.17.1.4.1.1.2 2
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.5 mgmt.1.17.1.4.1.1.5 5
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.6 mgmt.1.17.1.4.1.1.6 6
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.7 mgmt.1.17.1.4.1.1.7 7
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.8 mgmt.1.17.1.4.1.1.8 8
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.9 mgmt.1.17.1.4.1.1.9 9
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.10 mgmt.1.17.1.4.1.1.10 10
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.11 mgmt.1.17.1.4.1.1.11 11
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.12 mgmt.1.17.1.4.1.1.12 12
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.13 mgmt.1.17.1.4.1.1.13 13
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.14 mgmt.1.17.1.4.1.1.14 14
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.15 mgmt.1.17.1.4.1.1.15 15
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.16 mgmt.1.17.1.4.1.1.16 16
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.17 mgmt.1.17.1.4.1.1.17 17
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.18 mgmt.1.17.1.4.1.1.18 18
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.19 mgmt.1.17.1.4.1.1.19 19
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.20 mgmt.1.17.1.4.1.1.20 20
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.21 mgmt.1.17.1.4.1.1.21 21
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.22 mgmt.1.17.1.4.1.1.22 22
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.23 mgmt.1.17.1.4.1.1.23 23
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.24 mgmt.1.17.1.4.1.1.24 24
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.25 mgmt.1.17.1.4.1.1.25 25
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.26 mgmt.1.17.1.4.1.1.26 26
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.27 mgmt.1.17.1.4.1.1.27 27
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.28 mgmt.1.17.1.4.1.1.28 28
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.29 mgmt.1.17.1.4.1.1.29 29
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.30 mgmt.1.17.1.4.1.1.30 30
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.31 mgmt.1.17.1.4.1.1.31 31
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.1.32 mgmt.1.17.1.4.1.1.32 32
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.1 mgmt.1.17.1.4.1.2.1 1
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.2 mgmt.1.17.1.4.1.2.2 2
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.5 mgmt.1.17.1.4.1.2.5 9
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.6 mgmt.1.17.1.4.1.2.6 10
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.7 mgmt.1.17.1.4.1.2.7 11
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.8 mgmt.1.17.1.4.1.2.8 12
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.9 mgmt.1.17.1.4.1.2.9 13
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.10 mgmt.1.17.1.4.1.2.10 14
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.11 mgmt.1.17.1.4.1.2.11 15
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.12 mgmt.1.17.1.4.1.2.12 16
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.13 mgmt.1.17.1.4.1.2.13 17
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.14 mgmt.1.17.1.4.1.2.14 18
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.15 mgmt.1.17.1.4.1.2.15 19
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.16 mgmt.1.17.1.4.1.2.16 20
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.17 mgmt.1.17.1.4.1.2.17 21
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.18 mgmt.1.17.1.4.1.2.18 22
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.19 mgmt.1.17.1.4.1.2.19 23
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.20 mgmt.1.17.1.4.1.2.20 24
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.21 mgmt.1.17.1.4.1.2.21 25
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.22 mgmt.1.17.1.4.1.2.22 26
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.23 mgmt.1.17.1.4.1.2.23 27
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.24 mgmt.1.17.1.4.1.2.24 28
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.25 mgmt.1.17.1.4.1.2.25 29
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.26 mgmt.1.17.1.4.1.2.26 30
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.27 mgmt.1.17.1.4.1.2.27 31
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.28 mgmt.1.17.1.4.1.2.28 32
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.29 mgmt.1.17.1.4.1.2.29 33
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.30 mgmt.1.17.1.4.1.2.30 34
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.31 mgmt.1.17.1.4.1.2.31 35
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.2.32 mgmt.1.17.1.4.1.2.32 36
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.1 mgmt.1.17.1.4.1.3.1 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.2 mgmt.1.17.1.4.1.3.2 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.5 mgmt.1.17.1.4.1.3.5 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.6 mgmt.1.17.1.4.1.3.6 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.7 mgmt.1.17.1.4.1.3.7 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.8 mgmt.1.17.1.4.1.3.8 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.9 mgmt.1.17.1.4.1.3.9 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.10 mgmt.1.17.1.4.1.3.10 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.11 mgmt.1.17.1.4.1.3.11 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.12 mgmt.1.17.1.4.1.3.12 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.13 mgmt.1.17.1.4.1.3.13 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.14 mgmt.1.17.1.4.1.3.14 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.15 mgmt.1.17.1.4.1.3.15 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.16 mgmt.1.17.1.4.1.3.16 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.17 mgmt.1.17.1.4.1.3.17 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.18 mgmt.1.17.1.4.1.3.18 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.19 mgmt.1.17.1.4.1.3.19 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.20 mgmt.1.17.1.4.1.3.20 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.21 mgmt.1.17.1.4.1.3.21 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.22 mgmt.1.17.1.4.1.3.22 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.23 mgmt.1.17.1.4.1.3.23 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.24 mgmt.1.17.1.4.1.3.24 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.25 mgmt.1.17.1.4.1.3.25 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.26 mgmt.1.17.1.4.1.3.26 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.27 mgmt.1.17.1.4.1.3.27 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.28 mgmt.1.17.1.4.1.3.28 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.29 mgmt.1.17.1.4.1.3.29 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.30 mgmt.1.17.1.4.1.3.30 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.31 mgmt.1.17.1.4.1.3.31 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.3.32 mgmt.1.17.1.4.1.3.32 0.0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.1 mgmt.1.17.1.4.1.4.1 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.2 mgmt.1.17.1.4.1.4.2 381
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.5 mgmt.1.17.1.4.1.4.5 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.6 mgmt.1.17.1.4.1.4.6 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.7 mgmt.1.17.1.4.1.4.7 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.8 mgmt.1.17.1.4.1.4.8 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.9 mgmt.1.17.1.4.1.4.9 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.10 mgmt.1.17.1.4.1.4.10 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.11 mgmt.1.17.1.4.1.4.11 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.12 mgmt.1.17.1.4.1.4.12 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.13 mgmt.1.17.1.4.1.4.13 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.14 mgmt.1.17.1.4.1.4.14 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.15 mgmt.1.17.1.4.1.4.15 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.16 mgmt.1.17.1.4.1.4.16 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.17 mgmt.1.17.1.4.1.4.17 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.18 mgmt.1.17.1.4.1.4.18 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.19 mgmt.1.17.1.4.1.4.19 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.20 mgmt.1.17.1.4.1.4.20 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.21 mgmt.1.17.1.4.1.4.21 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.22 mgmt.1.17.1.4.1.4.22 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.23 mgmt.1.17.1.4.1.4.23 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.24 mgmt.1.17.1.4.1.4.24 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.25 mgmt.1.17.1.4.1.4.25 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.26 mgmt.1.17.1.4.1.4.26 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.27 mgmt.1.17.1.4.1.4.27 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.28 mgmt.1.17.1.4.1.4.28 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.29 mgmt.1.17.1.4.1.4.29 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.30 mgmt.1.17.1.4.1.4.30 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.31 mgmt.1.17.1.4.1.4.31 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.4.32 mgmt.1.17.1.4.1.4.32 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.1 mgmt.1.17.1.4.1.5.1 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.2 mgmt.1.17.1.4.1.5.2 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.5 mgmt.1.17.1.4.1.5.5 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.6 mgmt.1.17.1.4.1.5.6 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.7 mgmt.1.17.1.4.1.5.7 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.8 mgmt.1.17.1.4.1.5.8 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.9 mgmt.1.17.1.4.1.5.9 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.10 mgmt.1.17.1.4.1.5.10 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.11 mgmt.1.17.1.4.1.5.11 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.12 mgmt.1.17.1.4.1.5.12 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.13 mgmt.1.17.1.4.1.5.13 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.14 mgmt.1.17.1.4.1.5.14 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.15 mgmt.1.17.1.4.1.5.15 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.16 mgmt.1.17.1.4.1.5.16 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.17 mgmt.1.17.1.4.1.5.17 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.18 mgmt.1.17.1.4.1.5.18 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.19 mgmt.1.17.1.4.1.5.19 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.20 mgmt.1.17.1.4.1.5.20 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.21 mgmt.1.17.1.4.1.5.21 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.22 mgmt.1.17.1.4.1.5.22 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.23 mgmt.1.17.1.4.1.5.23 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.24 mgmt.1.17.1.4.1.5.24 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.25 mgmt.1.17.1.4.1.5.25 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.26 mgmt.1.17.1.4.1.5.26 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.27 mgmt.1.17.1.4.1.5.27 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.28 mgmt.1.17.1.4.1.5.28 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.29 mgmt.1.17.1.4.1.5.29 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.30 mgmt.1.17.1.4.1.5.30 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.31 mgmt.1.17.1.4.1.5.31 0
RFC1155-SMI 1.3.6.1.2.1.17.1.4.1.5.32 mgmt.1.17.1.4.1.5.32 0
RFC1155-SMI 1.3.6.1.2.1.17.2.1.0 mgmt.1.17.2.1.0 3
RFC1155-SMI 1.3.6.1.2.1.17.2.2.0 mgmt.1.17.2.2.0 32768
RFC1155-SMI 1.3.6.1.2.1.17.2.3.0 mgmt.1.17.2.3.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.4.0 mgmt.1.17.2.4.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.5.0 mgmt.1.17.2.5.0
RFC1155-SMI 1.3.6.1.2.1.17.2.6.0 mgmt.1.17.2.6.0 1
RFC1155-SMI 1.3.6.1.2.1.17.2.7.0 mgmt.1.17.2.7.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.8.0 mgmt.1.17.2.8.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.9.0 mgmt.1.17.2.9.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.10.0 mgmt.1.17.2.10.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.11.0 mgmt.1.17.2.11.0 0
RFC1155-SMI 1.3.6.1.2.1.17.2.12.0 mgmt.1.17.2.12.0 2000
RFC1155-SMI 1.3.6.1.2.1.17.2.13.0 mgmt.1.17.2.13.0 200
RFC1155-SMI 1.3.6.1.2.1.17.2.14.0 mgmt.1.17.2.14.0 1500
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.1 mgmt.1.17.2.15.1.1.1 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.2 mgmt.1.17.2.15.1.1.2 2
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.5 mgmt.1.17.2.15.1.1.5 5
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.6 mgmt.1.17.2.15.1.1.6 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.7 mgmt.1.17.2.15.1.1.7 7
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.8 mgmt.1.17.2.15.1.1.8 8
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.9 mgmt.1.17.2.15.1.1.9 9
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.10 mgmt.1.17.2.15.1.1.10 10
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.11 mgmt.1.17.2.15.1.1.11 11
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.12 mgmt.1.17.2.15.1.1.12 12
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.13 mgmt.1.17.2.15.1.1.13 13
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.14 mgmt.1.17.2.15.1.1.14 14
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.15 mgmt.1.17.2.15.1.1.15 15
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.16 mgmt.1.17.2.15.1.1.16 16
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.17 mgmt.1.17.2.15.1.1.17 17
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.18 mgmt.1.17.2.15.1.1.18 18
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.19 mgmt.1.17.2.15.1.1.19 19
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.20 mgmt.1.17.2.15.1.1.20 20
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.21 mgmt.1.17.2.15.1.1.21 21
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.22 mgmt.1.17.2.15.1.1.22 22
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.23 mgmt.1.17.2.15.1.1.23 23
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.24 mgmt.1.17.2.15.1.1.24 24
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.25 mgmt.1.17.2.15.1.1.25 25
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.26 mgmt.1.17.2.15.1.1.26 26
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.27 mgmt.1.17.2.15.1.1.27 27
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.28 mgmt.1.17.2.15.1.1.28 28
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.29 mgmt.1.17.2.15.1.1.29 29
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.30 mgmt.1.17.2.15.1.1.30 30
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.31 mgmt.1.17.2.15.1.1.31 31
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.1.32 mgmt.1.17.2.15.1.1.32 32
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.1 mgmt.1.17.2.15.1.2.1 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.2 mgmt.1.17.2.15.1.2.2 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.5 mgmt.1.17.2.15.1.2.5 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.6 mgmt.1.17.2.15.1.2.6 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.7 mgmt.1.17.2.15.1.2.7 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.8 mgmt.1.17.2.15.1.2.8 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.9 mgmt.1.17.2.15.1.2.9 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.10 mgmt.1.17.2.15.1.2.10 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.11 mgmt.1.17.2.15.1.2.11 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.12 mgmt.1.17.2.15.1.2.12 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.13 mgmt.1.17.2.15.1.2.13 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.14 mgmt.1.17.2.15.1.2.14 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.15 mgmt.1.17.2.15.1.2.15 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.16 mgmt.1.17.2.15.1.2.16 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.17 mgmt.1.17.2.15.1.2.17 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.18 mgmt.1.17.2.15.1.2.18 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.19 mgmt.1.17.2.15.1.2.19 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.20 mgmt.1.17.2.15.1.2.20 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.21 mgmt.1.17.2.15.1.2.21 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.22 mgmt.1.17.2.15.1.2.22 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.23 mgmt.1.17.2.15.1.2.23 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.24 mgmt.1.17.2.15.1.2.24 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.25 mgmt.1.17.2.15.1.2.25 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.26 mgmt.1.17.2.15.1.2.26 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.27 mgmt.1.17.2.15.1.2.27 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.28 mgmt.1.17.2.15.1.2.28 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.29 mgmt.1.17.2.15.1.2.29 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.30 mgmt.1.17.2.15.1.2.30 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.31 mgmt.1.17.2.15.1.2.31 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.2.32 mgmt.1.17.2.15.1.2.32 128
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.1 mgmt.1.17.2.15.1.3.1 5
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.2 mgmt.1.17.2.15.1.3.2 5
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.5 mgmt.1.17.2.15.1.3.5 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.6 mgmt.1.17.2.15.1.3.6 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.7 mgmt.1.17.2.15.1.3.7 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.8 mgmt.1.17.2.15.1.3.8 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.9 mgmt.1.17.2.15.1.3.9 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.10 mgmt.1.17.2.15.1.3.10 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.11 mgmt.1.17.2.15.1.3.11 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.12 mgmt.1.17.2.15.1.3.12 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.13 mgmt.1.17.2.15.1.3.13 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.14 mgmt.1.17.2.15.1.3.14 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.15 mgmt.1.17.2.15.1.3.15 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.16 mgmt.1.17.2.15.1.3.16 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.17 mgmt.1.17.2.15.1.3.17 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.18 mgmt.1.17.2.15.1.3.18 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.19 mgmt.1.17.2.15.1.3.19 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.20 mgmt.1.17.2.15.1.3.20 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.21 mgmt.1.17.2.15.1.3.21 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.22 mgmt.1.17.2.15.1.3.22 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.23 mgmt.1.17.2.15.1.3.23 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.24 mgmt.1.17.2.15.1.3.24 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.25 mgmt.1.17.2.15.1.3.25 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.26 mgmt.1.17.2.15.1.3.26 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.27 mgmt.1.17.2.15.1.3.27 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.28 mgmt.1.17.2.15.1.3.28 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.29 mgmt.1.17.2.15.1.3.29 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.30 mgmt.1.17.2.15.1.3.30 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.31 mgmt.1.17.2.15.1.3.31 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.3.32 mgmt.1.17.2.15.1.3.32 6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.1 mgmt.1.17.2.15.1.4.1 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.2 mgmt.1.17.2.15.1.4.2 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.5 mgmt.1.17.2.15.1.4.5 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.6 mgmt.1.17.2.15.1.4.6 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.7 mgmt.1.17.2.15.1.4.7 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.8 mgmt.1.17.2.15.1.4.8 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.9 mgmt.1.17.2.15.1.4.9 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.10 mgmt.1.17.2.15.1.4.10 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.11 mgmt.1.17.2.15.1.4.11 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.12 mgmt.1.17.2.15.1.4.12 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.13 mgmt.1.17.2.15.1.4.13 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.14 mgmt.1.17.2.15.1.4.14 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.15 mgmt.1.17.2.15.1.4.15 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.16 mgmt.1.17.2.15.1.4.16 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.17 mgmt.1.17.2.15.1.4.17 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.18 mgmt.1.17.2.15.1.4.18 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.19 mgmt.1.17.2.15.1.4.19 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.20 mgmt.1.17.2.15.1.4.20 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.21 mgmt.1.17.2.15.1.4.21 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.22 mgmt.1.17.2.15.1.4.22 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.23 mgmt.1.17.2.15.1.4.23 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.24 mgmt.1.17.2.15.1.4.24 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.25 mgmt.1.17.2.15.1.4.25 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.26 mgmt.1.17.2.15.1.4.26 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.27 mgmt.1.17.2.15.1.4.27 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.28 mgmt.1.17.2.15.1.4.28 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.29 mgmt.1.17.2.15.1.4.29 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.30 mgmt.1.17.2.15.1.4.30 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.31 mgmt.1.17.2.15.1.4.31 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.4.32 mgmt.1.17.2.15.1.4.32 1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.1 mgmt.1.17.2.15.1.5.1 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.2 mgmt.1.17.2.15.1.5.2 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.5 mgmt.1.17.2.15.1.5.5 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.6 mgmt.1.17.2.15.1.5.6 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.7 mgmt.1.17.2.15.1.5.7 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.8 mgmt.1.17.2.15.1.5.8 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.9 mgmt.1.17.2.15.1.5.9 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.10 mgmt.1.17.2.15.1.5.10 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.11 mgmt.1.17.2.15.1.5.11 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.12 mgmt.1.17.2.15.1.5.12 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.13 mgmt.1.17.2.15.1.5.13 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.14 mgmt.1.17.2.15.1.5.14 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.15 mgmt.1.17.2.15.1.5.15 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.16 mgmt.1.17.2.15.1.5.16 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.17 mgmt.1.17.2.15.1.5.17 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.18 mgmt.1.17.2.15.1.5.18 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.19 mgmt.1.17.2.15.1.5.19 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.20 mgmt.1.17.2.15.1.5.20 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.21 mgmt.1.17.2.15.1.5.21 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.22 mgmt.1.17.2.15.1.5.22 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.23 mgmt.1.17.2.15.1.5.23 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.24 mgmt.1.17.2.15.1.5.24 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.25 mgmt.1.17.2.15.1.5.25 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.26 mgmt.1.17.2.15.1.5.26 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.27 mgmt.1.17.2.15.1.5.27 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.28 mgmt.1.17.2.15.1.5.28 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.29 mgmt.1.17.2.15.1.5.29 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.30 mgmt.1.17.2.15.1.5.30 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.31 mgmt.1.17.2.15.1.5.31 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.5.32 mgmt.1.17.2.15.1.5.32 100
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.1 mgmt.1.17.2.15.1.6.1
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.2 mgmt.1.17.2.15.1.6.2
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.5 mgmt.1.17.2.15.1.6.5
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.6 mgmt.1.17.2.15.1.6.6
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.7 mgmt.1.17.2.15.1.6.7
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.8 mgmt.1.17.2.15.1.6.8
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.9 mgmt.1.17.2.15.1.6.9
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.10 mgmt.1.17.2.15.1.6.10
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.11 mgmt.1.17.2.15.1.6.11
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.12 mgmt.1.17.2.15.1.6.12
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.13 mgmt.1.17.2.15.1.6.13
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.14 mgmt.1.17.2.15.1.6.14
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.15 mgmt.1.17.2.15.1.6.15
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.16 mgmt.1.17.2.15.1.6.16
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.17 mgmt.1.17.2.15.1.6.17
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.18 mgmt.1.17.2.15.1.6.18
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.19 mgmt.1.17.2.15.1.6.19
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.20 mgmt.1.17.2.15.1.6.20
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.21 mgmt.1.17.2.15.1.6.21
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.22 mgmt.1.17.2.15.1.6.22
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.23 mgmt.1.17.2.15.1.6.23
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.24 mgmt.1.17.2.15.1.6.24
RFC1155-SMI 1.3.6.1.2.1.17.2.15.1.6.25 mgmt.1.17.2.15.1.6.25
