AP 3700 can not join WLC
QuangTran99
Hello all,
I need your help. Thanks so much.
I have master AP 3800 with version : 8.5.151.0
Another 3800 can join WLC, but 3700 can not join
OS for 3700 is: ap3g2-k9w8-tar.153-3.JPJ2.tar
Please see attached file for details logs.
2 Accepted Solutions
HaifengLi
The versions of the ME and AP do not match. For details, refer to the Deployment Guide.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_cisco_mobility_express_8_5/b_cisco_mobility_express_8_5_chapter_0111.html#concept_4E1DCD5CC7A74E9FA52AF3B393D071D8
Upgrading the AP version directly is also an option.
If the Controller version is 8.5.151, the AP version should be 15.3 (3) JF10.
* Note that you should choose C3700 instead of AP3G2.
#archive download-sw /reload tftp://<tftp server ip address>/<filename.tar>
  1. Go HERE
  2. Download the file "ap3g2-rcvk9w8-tar.153-3.JK1.tar" and put it into your TFTP server.
  3. On the AP, enter the following command
    archive download-sw /over tftp://<TFTP_IP_ADDRESS>/ap3g2-rcvk9w8-tar.153-3.JK1.tar
  4. Reboot the AP.
14 Replies 14
Leo Laohoo
Console into the AP and post the complete output to the command "dir".
HaifengLi
Download image failed, notify controller!!! From:17.1.1.29 to 0.0.0.0, FailureCode:3
@HaifengLi
The AP has joined a 9800 loaded with Amsterdam-17.1.1 and it is trying to go back to AeroOS.
That is why I'm asking to see directory contents to see if the AP still have an RCV folder or not.
I'm not sure, but I think 140.231.150.45 is the ME (Controller) IP address, and the log looks like join fails because the image cannot be downloaded.
It doesn't look like joined to C9800 now, but as you said AP is trying to join AeroOS.
So if tftp / ftp is set on the ME (Controller) to upgrade the AP, or directly upgrade the AP, it may work.
Well, if the RCV folder is still available, then delete the all the CAPWAP folders and reboot the AP.
Because there is only one valid IOS left, the AP is guaranteed to boot into RCV.
WARNING:  This is a 2700/3700 AP trying to join a controller running 8.5.X.X.  There is a "feature" whereby the AP will download the firmware (from the controller) TWICE, reboot TWICE before the radios start serving clients.  We call this behaviour as  "double-download".
Thanks @Leo Laohoo !!! Below from 'dir' command. There is only one AireOS and no RCV folder. And I did reset twice, the same error.
AP0062.ec3c.6db4#dir
Directory of flash:/
2 -rwx 287 Jan 1 1970 00:06:33 +00:00 info
3 -rwx 148750 Mar 1 1993 03:26:20 +00:00 event.r1
237 drwx 2496 Mar 2 1993 06:05:20 +00:00 ap3g2-k9w8-mx.153-3.JPJ2
4 drwx 0 Mar 15 2020 08:43:17 +00:00 update
6 -rwx 1917 Mar 2 1993 06:07:28 +00:00 config.txt
7 -rwx 72017 Mar 2 1993 06:07:38 +00:00 event.log
38 -rwx 64 Mar 2 1993 05:29:19 +00:00 sensord_CSPRNG0
11 -rwx 1917 Mar 2 1993 06:07:28 +00:00 config.txt.bak
40 -rwx 64 Mar 2 1993 05:29:19 +00:00 sensord_CSPRNG1
41 -rwx 37823 Mar 5 1993 03:33:18 +00:00 event.r0
8 drwx 0 Mar 2 1993 05:18:34 +00:00 configs
10 -rwx 12312 Mar 15 2020 08:43:22 +00:00 private-multiple-fs
12 -rwx 1915 Mar 2 1993 06:07:28 +00:00 private-config
13 -rwx 323 Mar 15 2020 05:10:39 +00:00 env_vars
236 -rwx 4 Mar 7 1993 00:59:51 +00:00 FOC20163K1L
244 -rwx 356764 Mar 8 1993 08:40:23 +00:00 crashinfo_19930308-154023-+0700
Thanks, the output is very helpful.
This is the reason why the AP cannot download the firmware.
Issue the following commands:
debug capwap console cli
delete /f /r flash:update
Reboot the AP and see if the AP can now download the firmware from the controller.
"update" is deleted from flash. But the same error. There might be no correct image from my Controller. Should I change AP image to "c3700-k9w8-tar.153-3.JF10.tar" as @HaifengLi 's advice, and upgrade directly instead of from Controller?
4 -rwx 324 Mar 15 2020 09:20:00 +00:00 env_vars
7 -rwx 78701 Mar 15 2020 09:20:09 +00:00 event.log
38 -rwx 64 Mar 15 2020 09:20:00 +00:00 sensord_CSPRNG0
40 -rwx 64 Mar 15 2020 09:20:00 +00:00 sensord_CSPRNG1
10 -rwx 12312 Mar 15 2020 09:24:50 +00:00 private-multiple-fs
Post the complete output to the WLC command "sh ap bundle all".
Sorry, no command "show ap bundle all". Only command "show ap packet-dumb"
AP0062.ec3c.6db4>show ap ?
packet-dump AP packet-dump commands
or
AP0062.ec3c.6db4#show ap ?
  1. Go HERE
  4. Reboot the AP.
Hi @Leo Laohoo and @HaifengLi ,
With "c3700-k9w8-tar.153-3.JF10.tar", all 3700 APs can join 3800 WLC. Thanks you all for very prompt support.
Hi @HaifengLi ,
I will ask my partner for 15.3 (3) JF10. Is the link below correct location for JF10:
https://software.cisco.com/download/home/285029867/type/280775090/release/15.3.3-JF10
Thanks.
