AP 3800i showing on WLC5520 "PoE/Medium Power (15.4 W)" connected with switch Catalyst 9300
Raphael10
AP 3800i showing on WLC5520 "PoE/Medium Power (15.4 W)" connected with switch Catalyst 9300. I have 36 APs connected on WLC 5520 but only 6 APs show the protocols Down "PoE/Medium Power (15.4 W)"..
6 Replies 6
Leo Laohoo
What is the firmware running on the 5520?
Post the complete output to the command "sh power inline".
The firmware is 8.3.141.0.
The Firmware is 8.3.141.0
Follow the output command:
BRCSF-HQTI-AC19-01#show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 1590.0 227.0 1363.0
Interface Admin Oper Power Device Class Max
(Watts)
Tw1/0/1 auto on 15.4 Ieee PD 4 60.0
Tw1/0/2 auto on 15.4 Ieee PD 4 60.0
Tw1/0/3 auto on 15.4 Ieee PD 4 60.0
Tw1/0/4 auto on 30.0 Ieee PD 4 60.0
Tw1/0/5 auto on 15.4 Ieee PD 4 60.0
Tw1/0/6 auto on 15.4 Ieee PD 4 60.0
Tw1/0/7 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw1/0/8 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw1/0/9 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw1/0/10 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw1/0/11 auto off 0.0 n/a n/a 60.0
Tw1/0/12 auto off 0.0 n/a n/a 60.0
Tw1/0/13 auto off 0.0 n/a n/a 60.0
Tw1/0/14 auto off 0.0 n/a n/a 60.0
Tw1/0/15 auto off 0.0 n/a n/a 60.0
Tw1/0/16 auto off 0.0 n/a n/a 60.0
Tw1/0/17 auto off 0.0 n/a n/a 60.0
Tw1/0/18 auto off 0.0 n/a n/a 60.0
Tw1/0/19 auto off 0.0 n/a n/a 60.0
Tw1/0/20 auto off 0.0 n/a n/a 60.0
Tw1/0/21 auto off 0.0 n/a n/a 60.0
Tw1/0/22 auto off 0.0 n/a n/a 60.0
Tw1/0/23 auto off 0.0 n/a n/a 60.0
Tw1/0/24 auto off 0.0 n/a n/a 60.0
Tw1/0/25 auto off 0.0 n/a n/a 60.0
(Watts)
Tw1/0/26 auto off 0.0 n/a n/a 60.0
Tw1/0/27 auto off 0.0 n/a n/a 60.0
Tw1/0/28 auto off 0.0 n/a n/a 60.0
Tw1/0/29 auto off 0.0 n/a n/a 60.0
Tw1/0/30 auto off 0.0 n/a n/a 60.0
Tw1/0/31 auto off 0.0 n/a n/a 60.0
Tw1/0/32 auto off 0.0 n/a n/a 60.0
Tw1/0/33 auto off 0.0 n/a n/a 60.0
Tw1/0/34 auto off 0.0 n/a n/a 60.0
Tw1/0/35 auto off 0.0 n/a n/a 60.0
Tw1/0/36 auto off 0.0 n/a n/a 60.0
Te1/0/37 auto off 0.0 n/a n/a 60.0
Te1/0/38 auto off 0.0 n/a n/a 60.0
Te1/0/39 auto off 0.0 n/a n/a 60.0
Te1/0/40 auto off 0.0 n/a n/a 60.0
Te1/0/41 auto off 0.0 n/a n/a 60.0
Te1/0/42 auto off 0.0 n/a n/a 60.0
Te1/0/43 auto off 0.0 n/a n/a 60.0
Te1/0/44 auto off 0.0 n/a n/a 60.0
Te1/0/45 auto off 0.0 n/a n/a 60.0
Te1/0/46 auto off 0.0 n/a n/a 60.0
Te1/0/47 auto off 0.0 n/a n/a 60.0
Te1/0/48 auto off 0.0 n/a n/a 60.0
2 490.0 210.8 279.2
(Watts)
Tw2/0/1 auto on 15.4 Ieee PD 4 60.0
Tw2/0/2 auto on 30.0 Ieee PD 4 60.0
(Watts)
Tw2/0/3 auto on 15.4 Ieee PD 4 60.0
Tw2/0/4 auto off 0.0 n/a n/a 60.0
Tw2/0/5 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw2/0/6 auto on 30.0 Ieee PD 4 60.0
Tw2/0/7 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw2/0/8 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw2/0/9 auto on 30.0 AIR-AP3802I-Z-K9 4 60.0
Tw2/0/10 auto off 0.0 n/a n/a 60.0
Tw2/0/11 auto off 0.0 n/a n/a 60.0
Tw2/0/12 auto off 0.0 n/a n/a 60.0
Tw2/0/13 auto off 0.0 n/a n/a 60.0
Tw2/0/14 auto off 0.0 n/a n/a 60.0
Tw2/0/15 auto off 0.0 n/a n/a 60.0
Tw2/0/16 auto off 0.0 n/a n/a 60.0
Tw2/0/17 auto off 0.0 n/a n/a 60.0
Tw2/0/18 auto off 0.0 n/a n/a 60.0
Tw2/0/19 auto off 0.0 n/a n/a 60.0
Tw2/0/20 auto off 0.0 n/a n/a 60.0
Tw2/0/21 auto off 0.0 n/a n/a 60.0
Tw2/0/22 auto off 0.0 n/a n/a 60.0
Tw2/0/23 auto off 0.0 n/a n/a 60.0
Tw2/0/24 auto off 0.0 n/a n/a 60.0
Tw2/0/25 auto off 0.0 n/a n/a 60.0
Tw2/0/26 auto off 0.0 n/a n/a 60.0
Tw2/0/27 auto off 0.0 n/a n/a 60.0
Tw2/0/28 auto off 0.0 n/a n/a 60.0
Tw2/0/29 auto off 0.0 n/a n/a 60.0
Tw2/0/30 auto off 0.0 n/a n/a 60.0
Tw2/0/31 auto off 0.0 n/a n/a 60.0
Tw2/0/32 auto off 0.0 n/a n/a 60.0
Tw2/0/33 auto off 0.0 n/a n/a 60.0
Tw2/0/34 auto off 0.0 n/a n/a 60.0
Tw2/0/35 auto off 0.0 n/a n/a 60.0
--More--
`tis a bug with the firmware. I can see the AP is negotiating properly at 30.0w. I have similar issue with 1562 and TAC confirms it's a "cosmetic" bug which they are not prioritizing to fix because it's not critical to the operation(s) of the AP.
Hi Leo,
     For me is critical case because the APs showing the Status Down (2.4GHz and 5GHz) not working with POE Medium power (15.4w).
     I have a open case on Cisco TAC support about this issues.
     Thank you for your help!
Yes. We solved the problem. I enabled the CDP command on All AP´s connected directly on switch and I forced the command duplex full in the ports. After these commands the APs are working fine.
