Ap AIR-SAP1602E couldn't join the controller
osman.elhanafy
Dears,
i have an AP 1600 series, it couldn't join the controller and i got that error
AP18e7.28f7.63d3#
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Nov 6 13:34:37.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.90:5246
*Nov 6 13:34:38.003: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface is getting down
*Nov 6 13:34:38.003: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface is getting down
*Nov 6 13:34:38.063: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Nov 6 13:34:38.063: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Nov 6 13:34:38.075: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Nov 6 13:34:38.075: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Nov 6 13:34:38.099: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Nov 6 13:34:38.099: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 6 13:34:39.103: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 6 13:34:39.147: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 6 13:34:39.155: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 6 13:34:40.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 6 13:34:40.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 6 13:34:40.175: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 6 13:34:40.183: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 6 13:34:40.191: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 6 13:34:41.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 6 13:34:41.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 6 13:34:41.227: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 6 13:34:42.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 6 13:35:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.90 peer_port: 5246
*Nov 6 13:35:06.363: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.100.90 peer_port: 5246
*Nov 6 13:35:06.363: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.90
*Nov 6 13:35:11.363: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.90
*Nov 6 13:36:05.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.90:5246
*Nov 6 13:36:06.003: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface is getting down
*Nov 6 13:36:06.003: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface is getting down
*Nov 6 13:36:06.063: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Nov 6 13:36:06.063: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Nov 6 13:36:06.075: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Nov 6 13:36:06.075: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Nov 6 13:36:06.099: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Nov 6 13:36:06.099: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 6 13:36:06.099: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Nov 6 13:36:06.103: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 6 13:36:06.111: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface reset
*Nov 6 13:36:06.151: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 6 13:36:07.103: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 6 13:36:07.147: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 6 13:36:07.155: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 6 13:36:08.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 6 13:36:08.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 6 13:36:08.175: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 6 13:36:08.183: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 6 13:36:08.191: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 6 13:36:09.175: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 6 13:36:09.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 6 13:36:09.227: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 6 13:36:10.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
AP18e7.28f7.63d3#
any one faced this problem before?
thanks
osman.elhanafy
The problem was on license.
i deactivated and activated it again then it worked.
7 Replies 7
Scott Fella
You don’t have much info. Are you on the supported wlc version?
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Make sure you set the time one the WLC, the AP gets an ip and is on the same subnet as the wlc management. Try that first.
-Scott
Sandeep Choudhary
As Scott mentioned....we need more info to find out the root cause.
paste the output of these commands:
sh version from cisco AP
sh sysinfo from WLC
Dont forget toi rate helpful posts
Dears,
kindly find below the required output
AP18e7.28f7.63d3#show version
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.3(3)JF8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 20-Jul-18 20:27 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP18e7.28f7.63d3 uptime is 5 minutes
System image file is "flash:ap1g2-k9w8-mx.153-3.JF8/ap1g2-k9w8-xx.153-3.JF8"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602E-E-K9 (PowerPC) processor (revision B0) with 187386K/74672K bytes of memory.
Processor board ID FGL1816W2AD
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.5.135.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 18:E7:28:F7:63:D3
Part Number : 73-14508-04
PCB Serial Number : FOC18113N1R
Top Assembly Part Number : 800-38553-01
Top Assembly Serial Number : FGL1816W2AD
Top Revision Number : A0
Product/Model Number : AIR-SAP1602E-E-K9
Configuration register is 0xF
AP18e7.28f7.63d3#
sysinfo syslog system
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.143.0
RTOS Version..................................... 8.3.143.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.3.143.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... Cisco_be:20:03
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.100.90
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 35 mins 29 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... EG - Egypt
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 00:0C:29:BE:20:03
Maximum number of APs supported.................. 3000
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Large
How many AP licenses are enabled on the vWLC?
I think the Regulatory Domain of the AP is incorrect.
issue si the cmptbiity between AP(Europe) and WLC(Egypt) regulatory domain .
So to make it work, either you need to use any Europain country code on WLC (Which is not recommanded ) or swap/change the AP with correct regulatory domain (Probably 1602E-I-K9 or 1602E-C-K9 )
Dont forget to arte helpful posts
osman.elhanafy
Thanks, i solved too with this change
