AP and Bridge simultaneously
Alex.Savin
Community Member
Can I use AP/BR1300 as wireless bridge and AP simultaneously. I would like to use AIR-WGB352R as bridge and AIR-PCI352 as adapter.
gamccall
Level 8
Level 8
If I understand you correctly, you want to configure your 1300 so that it will accept associations from both PC clients and from a WGB352.
If that's the case, then you'll just put the 1300 into Access Point mode. The WGB352 is not a true bridge as such; it's a workgroup bridge which means that it needs to associate with an upstream AP, not with another bridge.
