07-29-2004 07:59 AM - edited 07-04-2021 09:50 AM
I'm sorry for this new posting.
Summary of what I did:
recently updated our AP 340 from 11.08 to 12.04.
Now the Apple MACs don't "see" the network.
They use the latest Apple AirportSoftware and worked perfectly before the update.
I found in this forum the following options and made them:
non-Aironet 802.11
use Aironet extensions: no
Radio Preamble: LONG
Ethernet enc. transf.: RFC1042
Radio modulation -> Standard
The LOGs of the accesspoint are empty, WEP is off, I broadcast the SSID (checked the name four times).
Nothing helped. What can I do now?
Thanks!
Marko
08-03-2004 08:47 PM
Other windows client works fine ? Can you please
tell detail about airport driver version ?
In this case wireless sniffer traces will help
thanks
08-05-2004 06:30 AM
Hi!
We tested three different configurations:
iMac G4, Jaguar (10.2.8): Airport software 3.1.2
Powerbook G4, Panther (10.3.4): Airport software 3.4.2
These two using 11MBit Airport.
This Powerbook uses Airport Extreme (54MBit) and doesn't see the network with the old and 12.04 firmware.
The settings of the AP 340 are like I mentioned in my last posting.
These are the settings:
Network 5: "l3stest" BSSID: "00:40:96:34:D9:7A"
Type : infrastructure
Carrier : 802.11b
Info : "None"
Channel : 01
WEP : "No"
Maxrate : 0.0
LLC : 4
Data : 32
Crypt : 0
Weak : 0
Total : 36
First : "Thu Aug 5 16:14:30 2004"
Last : "Thu Aug 5 16:14:53 2004"
Min Loc: Lat 90.000000 Lon 180.000000 Alt 0.000000 Spd 0.000000
Max Loc: Lat -90.000000 Lon -180.000000 Alt 0.000000 Spd 0.000000
Address found via UDP 0.0.0.0
Thanks in advance.
Marko
