04-08-2021 07:40 PM - edited 07-05-2021 01:07 PM
Hello, Diagram is like this: WLC-------SW------AP
Two SSIDs(abc10 and abc20) are created and associated with two interfaces(vlan10 and 20) respectively at WLC. The AP is connected to the SW at access mode with vlan 10. The SSID abc20 can be sent out via the AP? Thank you
Solved! Go to Solution.
04-08-2021 08:03 PM
AP Groups
04-08-2021 08:03 PM
AP Groups
04-08-2021 08:50 PM
Thank you!
04-08-2021 09:48 PM
04-09-2021 05:58 PM
Thanks for your reply. We have two vlans: one is for employee and other is contractor(or guest). If the AP is connected (access mode) to the switch, is it possible for the AP to send out two SSIDs for employee and contractor respectively? I can see a lot people use trunk for the function, not sure if access mode can do it.
