AP2702i AP won't join 9800 vWLC - DLTS handshake error
liormo
Hello, I've setup an internal lab which uses the 9800 WLC (on AWS with a VPN to our lab). And now i'm trying to onboard an out of the box 2702i AP.
The join process fails:
CAPWAP DTLS session closed for AP, cause: DTLS handshake error
* The AP is currently using DHCP 43 option to get the WLC details. are there any other options that needs to be sent (NTP?)
Attached image of packet capture.
7 Replies 7
Jurgens L
Level 3
Level 3
Did you ensure you generated a certificate for the AP's on the WLC?
wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0 <pwd>
Yes, I ran this command before adding the AP. Are there any debug commands which might be useful here?
I haven't logged in to the AP yet . Maybe there are some commands that needs to be executed on the AP before?
You may want to check the syslogs on the WLC otherwise I will suggest getting on the AP cli and see the output. The 9800's come with a 90-day trial license, you can always just double check that under administration > licensing in the GUI.
What kind of license do you have for the AP?
As for the 9800 WLC there is no "add AP license", so the AP needs to have an AIR-DNA license on the smart license portal.
Ralph Olsen
I did:
clear capwap ap all-config
That worked.
Thanks, this worked for me took me lots of googling to find this answer
I first tried clear lwapp private-config and that didn't work at all
ammahend
9800 required mandatory smart license for APs to register, might be an issue with licensing, what the smart license status (see image)
-hope this helps-
