AP Cisco 1100 repeater with AP Cisco 350?
gchoque
I need to install an AP Cisco 1100 as repeater of an AP350 but does not result me.
It is possible?,
If I configure an AP1100 as Root and another AP1100 as repeater they function correctly, but if I configure the AP350 as Root and the AP1100 as Repeater not the link is achieved. Which is the problem?
Thank you
kmarrero
Level 4
Level 4
The 350 and the 1100 should connect to each other with no problems. First check to make sure the 350 works with another 350 access point if possible. If it does work with another AP then there is most likely a configuration issue which could be fixed by defaluting both access points back to factory defaults and reconfiguring them. It is also advised that both access points be on the same version of firmware if possible. Here are a few URLs that may help you. http://www.cisco.com/warp/public/102/wlan/pwrec-2.html and http://www.cisco.com/warp/public/102/wlan/connectivity.html#accesspoints
