AP Client Authentication Issues
cayoung81
Community Member
Hello. I have three 1200 series access points running in autonomous mode that need to allow handheld computers to connect. The handhelds need to authenticate using EAP. The AP's are properly listed and configured in the ACS and the handhelds are properly set up as well, but when I do "show dot11 association" it shows them authenticated with aaa instead of eap. As I said, these are autonomous, so there is no WLC. The vlan being used for the AP's is properly trunked all the way back to where the traffic needs to go. Here is a configuration example:
interface Dot11Radio0
 no ip address
 no shut
 no ip route-cache
 encryption mode wep mandatory
 ssid portableclient
 speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
 channel 2412
 station-role root
 rts threshold 2312
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
aaa new-model
aaa group server radius rad_eap
 server x.x.x.x auth-port 1645 acct-port 1646
aaa group server radius rad_m
aaa group server radius rad_a
aaa group server radius rad_ad
aaa group server tacacs+ tac_ad
aaa group server radius rad_p
aaa group server radius dummy
ip http authentication aaa
no ip http secure-server
ip tacacs source-interface BVI1
ip radius source-interface BVI1
tacacs-server host x.x.x.x
tacacs-server timeout 20
tacacs-server directed-request
tacacs-server key xxxxxxxx
radius-server attribute 32 include-in-access-req format %h
radius-server host x.x.x.x auth-port 1645 acct-port 1646
radius-server timeout 20
radius-server deadtime 3
radius-server key xxxxxxxxx
radius-server vsa send accounting
bridge 1 route ip
The Clients connect to the AP but authenticate with aaa and therefore do not transmit as the Handhelds require radius. Any ideas of what I might be missing?
8 Replies 8
kcnajaf
Level 11
Level 11
Could you please share full AP configuration?
You have missed important parts of configurations.
Najaf
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname
logging buffered 1048576 debugging
enable secret
ip subnet-zero
no ip source-route
ip domain list
ip domain list
ip domain name
ip name-server
ip name-server
ip name-server
dot11 syslog
dot11 ssid
   authentication open eap eap_methods
   authentication network-eap eap_methods
   accounting acct_methods
   infrastructure-ssid
dot11 network-map
dot1x timeout reauth-period server
bridge irb
 no ip address
 no shut
 no ip route-cache
 ssid
 channel 2412
 station-role root
 rts threshold 2312
 bridge-group 1
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
ip default-gateway
no ip http server
logging trap notifications
logging source-interface BVI1
logging
access-list 2 permit
snmp-server community
snmp-server ifindex persist
snmp-server trap-source BVI1
snmp-server host 1 snmp
banner motd  ^
line con 0
 exec-timeout 30 0
 transport preferred telnet
 login
 password
 stopbits 1
line vty 0 4
 exec-timeout 30 0
 login
 password
line vty 5 15
 exec-timeout 30 0
 login
 password
sntp server
aaa new-model
 server  auth-port 1645 acct-port 1646
tacacs-server host
tacacs-server host
tacacs-server host
tacacs-server key
radius-server host  auth-port 1645 acct-port 1646
radius-server key
bridge 1 route ip
aaa authentication attempts login 4
aaa authentication password-prompt Password(local):
aaa authentication username-prompt User(local):
aaa authentication login default group tacacs+ enable
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
end
Hope you have not modified the running configuration. For some reason i cannot find the radius server ip address any where. I hope you have removed it.
Do you have trouble with all wireless clients where they are not doing EAP or is it some clients only?
Can you enable "debug radius authentication" output please?
Najaf
Yes, all my radius ips were removed before posting. It is all wireless devices that connect to this new ap.
Can you enable "debug radius authentication" output please when a client try to connect?
Najaf
Hi Najaf,
I met the same issue.  Could you please advise as below "sh log" inforamtion? Thanks.
RADIUS-4-RADIUS_DEAD: RADIUS server XX.XX.XX.XX:1645,1646 is not responding.
RADIUS-4-RADIUS_ALIVE: RADIUS server XX.XX.XX.XX:1645,1646 is being marked alive.
DOT11-7-AUTH_FAILED: Station XXXX.XXXX.XXXX Authentication failed
Hi Najaf,
Could you please advise as below:
Below is the debug information:
RADIUS/ENCODE: Best Local IP-Address XX.XX.XX.XX for Radius-Server XX.XX.XX.XX
RADIUS(00000C77): Send Access-Request to XX.XX.XX.XX:1645 id 1645/126, len 149
User-Name           [1]   13  "XXXX"
RADIUS:  Framed-MTU          [12]  6   1400
RADIUS:  Called-Station-Id   [30]  16  "XXXX"
RADIUS:  Calling-Station-Id  [31]  16  "XXXX"
RADIUS:  Service-Type        [6]   6   Login                     [1]
RADIUS:  Message-Authenticato[80]  18
NAS-Port-Type       [61]  6   802.11 wireless           [19]
RADIUS:  NAS-Port            [5]   6   3429
RADIUS:  NAS-Port-Id         [87]  6   "3429"
RADIUS:  NAS-IP-Address      [4]   6   XX.XX.XX.XX
RADIUS:  Nas-Identifier      [32]  12  "XXXX-AP-01"
RADIUS: no sg in radius-timers: ctx 0x15EBA14 sg 0x0000
RADIUS: Retransmit to (XX.XX.XX.XX :1645,1646) for id 1645/118
RADIUS: no sg in radius-timers: ctx 0x1505D6C sg 0x0000
RADIUS: Retransmit to (XX.XX.XX.XX :1645,1646) for id 1645/120
RADIUS: no sg in radius-timers: ctx 0x15F30E4 sg 0x0000
RADIUS-4-RADIUS_DEAD: RADIUS server XX.XX.XX.XX :1645,1646 is not responding.
RADIUS-4-RADIUS_ALIVE: RADIUS server XX.XX.XX.XX :1645,1646 is being marked alive.
RADIUS: Retransmit to (XX.XX.XX.XX :1645,1646) for id 1645/126
RADIUS: no sg in radius-timers: ctx 0x116DEE8 sg 0x0000
RADIUS: Retransmit to (XX.XX.XX.XX :1645,1646) for id 1645/121
